Front Struts are going
Well, I bought my 1990 LS400 with bad front struts. I found two decently priced brands, Tokico and KYB. Not sure if anyone else has any recommendations for a good ride and good handling.
Another thing...what brake rotors are recommended, other than OEM ones.
Don't go cheap on rotors (unless they are an AMAZING price). What I've found from past experience with those cheapy rotors is that you can only machine them once if you're lucky (most times you cant due to the wear). That doesn't bode much for quality or heat dissipation.
I did a little bit of comparison, and KYB is at the top for struts. Brembo seems a good deal at tirerack. Should I get the KYB strut mounts and boot kit too? Tirerack has those.
