sway bar size
sway bar size
Does anyone know if 98 LS sway bars are the same size as a 96 LS.
Other treads say a 96 uses a 1 1/16 or 27 mm bushing in front and a 9/16 or 14 mm in the rear will these fit my 98 (energy type bushings)
Thanks
Thanks
I did a little bit of search and found this tread with no replies from a while back.
I tried ordering Poly Sway Bars Bushings from AutoZone today; they had a few bushings Like these
http://www.autozone.com/autozone/par...mString=search
But the guy did not know which one to order for my Lex. He told me to get the size diameter of the sway bar so he could know which one to order. are the above Measurements orrect ?.
I also looked into Daizen bushings but where the hell can U order them. their site has this vendors but I was able to to get in touch with anyone and one of the numbers is no longer in service.
http://www.daizensporttuning.com/menu/dealers.html
Where can I get these SWAY BAR BUSHINGS FROM. I called a nearby Lex Dealer and they wanted $19 for each front & $20 for each rear.
BahHumBug
lexus sells the oem RUBBER bushings.
if you want poly bushings you need to follow this thread: https://www.clublexus.com/forums/ls4...nder-20-a.html
and for the record there IS a difference in '95-97 and 98-00 sway bars.
ay3333
01-08-14 02:01 PM
