Traction control button not working!!!
Hey all
I just bought a 1994 LS400 last friday and everything on the car works great. But the other day i pressed the (Traction control off) button and it would not light up or work. So of course i get on here and search and could not find a fix for it. So i had some time and ran over to the salvage yard and grabbed 2 more buttons to see if they would work........no deal. The problem is, i think i should here or feel the button "stick " in kinda like the seat heater button. But none of the 3 buttons i have click in and stay. I was wondering if any one else has ever had this problem? If so what did you do to fix it? Is this button suppose to click and stay in the same as the seat heater button? I was planning on doing some mod's to this car and a need to turn off the traction control.
thanks
chris w
thanks
chris w
I will pull it out and check.........i mean i was screwing around with it yesterday and i was able to line lock the car in a parking lot. But then i wasnt sure if it was on or off. I need to pull the cluster out and check that bulb.....thats pretty easy. Do you know if that light comes on when you first start the car?......because mine does not come on at all.....ever. I was hoping that maybe the ecu runs a check on it and then it goes off....kinda like the (ABS) and (check engine) do. If anyone has traction control could you check this for me?
thanks
chris w
thanks
chris w
thanks
chris w
yes the trac off light next to the o/d and the ect light should come on when you turn the key to the on position and should go off shortly after you start the engine
the " trac " in the middle of the speedo should only come on if you loss traction
right ?
right ?
ok thanks............ mine does not come on at all ....ever. I am going to call the dealer and see if i can get a new bulb for it. I will update if that was the problem.
chris w
3UZ-FEEEE
Hey all
thanks
chris w
thanks
chris w
Just as a note, TRAC buttons never stick because it reverts back ON when the car is restarted. Unlike the PWR button which stays on all the time. Its part of design logic.
It seems like your lightbulb is burned out... had that on the SC's PWR button.
KPatel8483
08-29-03 02:07 PM
