Water pump replacement - 94 LS400
Old 09-08-07, 01:55 PM
Och
Och's Avatar
Default Water pump replacement - 94 LS400
So my water pump is bad, and I am looking to replace it. I've read the tutorial on lexls.com, and it seems like one hell of a job, however the tutorial is for water pump and timing belt. My timing belt only has around 30K on it, so there's no reason to replace it, and I want to know if I can skip any of the steps if I'm replacing the water pump only.
Old 09-08-07, 04:02 PM
trukn1
NELOC Mod
trukn1's Avatar
You can proably skip those sections which involve the timing belt only. Bottom line is, you still have to go thru all of the steps of un-installation just to get to the water pump. Unfortunately there is no way around it. This is why most people replace the TB AND Water Pump together, b/c it is such a pain to get to. Doing it once is bad enough but having to break it all apart again to do another component which could have been replaced b4 when it was all apart is even worse. Good luck.
Old 09-10-07, 08:02 AM
etex
etex's Avatar
.....and, while it open this time, why not replace the TB since the labor has effectivellty been done? For the cost of the belt, you would have another
90K miles before having to go back in. Would be a good time to also be sure the other items associated with the TB replacement are completed, as some of them may have seemed unneccessary 30K back.
Old 09-10-07, 08:52 AM
sonyman
sonyman's Avatar
Such as a replacement of the cam and crank seals.
Old 09-10-07, 09:30 PM
avalon42
avalon42's Avatar
For sure. Mine need to be done.
MellonC00
Hybrid Technology
01-02-19 09:17 AM
GibbsLexus
08-09-17 07:18 AM
OMAHA
35
01-28-16 11:05 PM
WB03LS430
12-09-08 08:49 AM
zach
01-08-07 05:21 AM
Quick Reply: Water pump replacement - 94 LS400
