98 LS400 Navigation Obsolete!
Old 05-14-07, 08:30 AM
BPiccinini
BPiccinini's Avatar
Default 98 LS400 Navigation Obsolete!
Just found out that Lexus will no longer support the Nav. system on my car.
Does anyone know of an aftermarket hard drive being supplied.
Thanks in advance,
Bob
Old 05-14-07, 05:11 PM
Kansas
Kansas's Avatar
The 2005 nav harddrive update for the 98-00 LS400 is available from http://www.lexus-parts.com/parts_detail.asp?id=88792
Lexus has been coming out with an update about every two years but I wonder if the 2005 one will be the last.
Old 05-14-07, 07:59 PM
TJW98LS
TJW98LS's Avatar
That just made my bad day even worse.
Old 05-14-07, 10:42 PM
BPiccinini
BPiccinini's Avatar
So the parts man at Lexus in Redwood City Ca. tells me.
Old 05-15-07, 10:21 PM
blange400
blange400's Avatar
Whats wrong with the nav, the unit ,or just that the data needs updating?
You can call these guys if you need a salvage unit.
T.A.P. Recycling - (800) 765-7100 Used Toyota and Lexus parts from the world's largest Toyota truck and car dismantler. Top quality new and used parts for your Toyota truck or car.
www.taprecycling.net/
Old 05-15-07, 11:11 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
-very outdated maps
-updates are pretty $$$y
-interface is NOT very nice to use.
Old 05-16-07, 07:02 PM
blange400
blange400's Avatar
Well, you can buy the update of the software at Sewell
or some other dealer and then sell the car ,
and buy a Platinum Ed. SF (no nav) and buy a map!!!
That'll solve the nav issue for good!!
Old 12-20-07, 11:48 AM
heyhowyado
heyhowyado's Avatar
Originally Posted by Kansas
The 2005 nav harddrive update for the 98-00 LS400 is available from http://www.lexus-parts.com/partdetai...bCategoryID=73
i called a dealer and they said it IS the last update.
do you guys think it's worth getting this update?? will there be a lot more information as far as streets, or is it more of an update for the "points of interest"?
my car was never updated...it has the original navi from 98...
they gave me a price of around $280 for the new hard drive.....
Old 12-20-07, 12:00 PM
TJW98LS
TJW98LS's Avatar
Well it is supposed to get rid of alot of POIs and add more streets. POI such as ATMS...i dont think ive once used my POI button. Hopefully this new update will add my city.
I should be getting one soon, so when i install it, i'll let you know how it is.
Old 12-20-07, 01:30 PM
heyhowyado
heyhowyado's Avatar
hey, cool...thank you.
will you be installing it yourself???
Old 12-20-07, 06:27 PM
TJW98LS
TJW98LS's Avatar
Yes,I'll do a DIY Thead on it.
Old 12-20-07, 08:09 PM
tcbted
tcbted's Avatar
Or, buy a cheap tomtom or Garmin navigation unit.
Old 12-20-07, 10:21 PM
TJW98LS
TJW98LS's Avatar
How tacky would 2 navis in one car look though?
Old 12-21-07, 04:29 AM
heyhowyado
heyhowyado's Avatar
exactly.....and if the update is decent, it would be cheaper than buying another navi..
Old 12-21-07, 06:37 AM
Kansas
Kansas's Avatar
I noticed in the 2 volume repair manual set for my 2000 LS400 (it has Nakamichi), that it looks like the same amplifier is used for both the navigation audio system and the standard audio system - or at least the connector pin configuration on the amps look identical. The Nakamichi amp is very different.
Would it be "plug and play" to substitute the standard audio system/HVAC in the center stack for the navigation/HVAC module?
Or, it you used a standard HVAC module, could you install an aftermarket in-dash nav / audio system? This recent post shows what is possible: https://www.clublexus.com/forums/sho...d.php?t=324707
Even the most inexpensive aftermarket nav systems announce street names, have millions of POIs and many can be updated via the Internet.
In-dash navs do look nice though if you are willing to spend the big bucks.
Here is my cheepo aftermarket nav "semi-permanently" installed on a bracket -- it cost less than the update for the 98-00 LS400 OEM nav. I'll probably replace it with a better but still sub-$300 Garmin nav sometime in the next year or two since the Magellan company seems to be imploding.
Marano
05-27-17 06:15 PM
4wheelin
10-11-12 02:31 PM
hydrocap
05-24-08 09:00 PM
Quick Reply: 98 LS400 Navigation Obsolete!
