Help! How to fix Yellow Fogs...
Old 04-15-07, 06:39 PM
Celsior400
Celsior400's Avatar
Default Help! How to fix Yellow Fogs...
I just realized on my 93 LS400 that the yellow inner foglights wont turn on...
anyone have any ideas? ive checked the fuses under the dash... dont know where it is exactly at!!
someone please help! haha
Old 04-15-07, 06:43 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
dead bulbs.....?
u know the fogs can only turn on when the low-beams are on right.?
Old 04-16-07, 07:15 AM
avalon42
avalon42's Avatar
I'd check the bulbs as PD stated. Here's something to help you out if it is the bulb...
http://www.lexls.com/tutorials/light...onversion.html
Old 04-16-07, 09:57 AM
Celsior400
Celsior400's Avatar
yeah i knew the low beams had to be on...maybe its just the foglights themselves... thanks for the link...helps a lot...
just in case...is there any fuses for them?
Old 04-18-07, 12:20 PM
runumhard
runumhard's Avatar
wow thanks for the info........
also does the fogs still work when you put aftermarket hid lights in??? after I put in my kit bothj fogs don't work now im not sure if both bulbs blew ... I know one was....
Old 04-18-07, 02:59 PM
PureDrifter
BahHumBug
no, they dont. you have to rewire the fogs so u can trigger them automatically. theres a thread around here somewhere on how to do it.
Old 04-18-07, 04:01 PM
runumhard
runumhard's Avatar
ok thanks for the info..... yeah the hid plug only has 2 wires going to the stock harness.... but if you find the info on how 2 make the fogs work then I would love the help... thanks guys.............
Old 04-18-07, 06:36 PM
PureDrifter
BahHumBug
theres a thread in teh LS forums, theres no reason u cant search for it.
theres even less reason for you to make a new thread on the same $&#*ing topic because u didnt search....
Old 04-21-07, 12:09 PM
runumhard
runumhard's Avatar
well if your going to get a **** fit ....show me the link??????????????????????
Old 04-21-07, 03:21 PM
PureDrifter
BahHumBug
someone bumped it up too, its currently 2 posts under this thread
https://www.clublexus.com/forums/sho...d.php?t=259014
Old 04-24-07, 10:26 AM
ylekiot1
ylekiot1's Avatar
Default Fogs
You may have corrosion on your fuse panel. The fog relay on the board under the steering wheel is know to have issues.
Old 04-24-07, 02:58 PM
PureDrifter
BahHumBug
thats the first time ive heard of this on the LS.....
adamz28
03-22-12 10:15 AM
dejavu157
10-18-10 08:55 PM
ChewyBalls
01-04-10 04:21 PM
dann707
07-16-09 11:54 AM
howiedoit
Lighting
13
05-02-03 08:53 PM
Quick Reply: Help! How to fix Yellow Fogs...
