Adding more camber (front)
Old 10-15-06, 04:43 AM
Joshwa
Joshwa's Avatar
Default Adding more camber (front)
I’m looking at running more camber in the front of my 91`. Now that I have some free time I’m wanting to play around with settings, and get my coilovers working a bit better ect.
I’ve done a quick search and it appears no one makes camber kits for our cars?? I ideally would like to reduce the amount on the rear and add to the front as per original question.
Thanks,
- Josh
Old 10-15-06, 10:24 AM
RA40
Super Moderator
RA40's Avatar
Dunno about the 1LS, the 2'nd gen has sufficient adjustment. I've got -1.5, camber, 1/16" toe front and -1 camber, 1/12" toe rear. The tires on the car are wearing nicely in spite of this. The last measurment taken, the inside edge was like .02 different than the outer edge. I like the handling but that is relative to the boat that it is.
Old 10-15-06, 02:12 PM
richonenz
richonenz's Avatar
Your LS has a fully adjustable front and rear end , you don't need a camber kit , they are adjustable just as they are !!
Old 10-15-06, 06:34 PM
Joshwa
Joshwa's Avatar
Interesting. When I got my wheel alignment the shop said they couldn’t do anything about the camber.
Maybe it was just too hard for them?
Old 10-16-06, 10:29 AM
RA40
Super Moderator
RA40's Avatar
Presuming it's similar to the 2LS set-up, they have to remove the lower engine cover to access the camber adjustment bolts. Lazy.
i2fat
Suspension and Brakes
05-11-15 03:14 PM
youngs3oo
11-24-12 07:18 PM
Soobz
IS - 1st Gen (2001-2005)
03-17-11 03:16 PM
ekrebs
01-15-09 06:51 AM
SPEED&ECO.
01-28-07 02:40 PM
Quick Reply: Adding more camber (front)
