fuel gauge problem
Old 09-08-06, 08:10 AM
branko77
branko77's Avatar
Default fuel gauge problem
Hi guys,
I also have a similar problem and the banging in the dash board does the job for the speedometer and tachometer but not for the fuel gauge needle. The thing is that my fuel gauge doesn't accuratly show the fuel level in the gas tank. It shows that the tank is empty when it's actually half full. In order to get it to work I ordered a completely new buoey and the whole new fuel gauge instrument from Lexus Austria in Vienna. Installed the new instruments and the bouey but the problem presisted and got even worse. It started kind of a chain reaction, my speedometer and tachometer started gettin' lazy during high humidity and temperatures here in Belgarde, Serbia.
Please help on how to get the all those instruments working again normally beacuse there aren't any Lexus services except Toyota ones.
Old 09-08-06, 03:31 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
read the first thread in the forum. you likely need to replace the whole gauge cluster.
Old 09-09-06, 11:02 AM
branko77
branko77's Avatar
Already did that it still doesn't work prpoerly. It shows the maximum and minimum fuel quantaty until the warning lamp turns on. It doesn't show anything in between, it's either all the way up or down. Any other ideas
Old 09-09-06, 11:14 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
You might have a fuel sending unit problem. Just a thought. Never heard of the symptoms you discribe.
Old 09-10-06, 11:20 AM
branko77
branko77's Avatar
i had already changed fuel sending unit and the fuel gauge instrument on the panel and still have problem with fuel level
tjfrom215
SC- 1st Gen (1992-2000)
06-23-10 05:44 PM
Twix
20
03-27-10 10:21 PM
Blk97SC300
Performance & Maintenance
08-29-07 10:55 AM
Vyker
IS - 1st Gen (2001-2005)
02-17-07 01:41 PM
Jewcano
25
02-07-06 10:01 AM
Quick Reply: fuel gauge problem
