Engine dies after cranking. Will run w/foot on gas!
Old 07-21-06, 09:41 AM
samjwilson
samjwilson's Avatar
Default Engine dies after cranking. Will run w/foot on gas!
My car runs fine IF my foot is on the gas. When i take my foot off the pedal, it dies? HELP!
Old 07-21-06, 10:48 PM
skperformance
skperformance's Avatar
You have to clean you throttlebody.
Old 07-24-06, 01:24 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
check engine light on?
Old 07-25-06, 08:14 AM
samjwilson
samjwilson's Avatar
Default Engine shuts off when foot is removed from accelerator
No check engine light. The funny thing is, this started as an intermittent problem. Is cleaning thorttle body a hard job?
Old 07-25-06, 08:30 AM
samjwilson
samjwilson's Avatar
Thanks. Is this hard to do? Any pics or tutorials?
Old 07-25-06, 09:10 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
theres a tutorial on lextreme
http://www.lextreme.com/tb.htm
Old 07-25-06, 09:37 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Has the car been sitting for some time? This had happend to me. If I were you, I would take out the ECU fuse, or pull the battery cable off for 20mins to reset the ECU.
Old 07-28-06, 09:47 AM
samjwilson
samjwilson's Avatar
This weekend i will clean the TB. How do I locate the ECU fuse? BTW I replace a dead batt. Should i still pull ECU FUSE?
Old 07-28-06, 11:07 AM
PureDrifter
BahHumBug
no, if the battery was dead and u replaced u prolly left it disconnected for ~5mins, which is long enough to reset the ECU.
Old 07-28-06, 11:30 AM
samjwilson
samjwilson's Avatar
Thank you. I will give the TB cleaning a shot on Sunday! Wish me luck!
Old 07-31-06, 09:49 PM
jgdynamics
jgdynamics's Avatar
check ur vacuum connections also.. maybe something came loose or broke.. very common problem for mr2 owners as well
Old 07-31-06, 10:05 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
i second that.
lyonkster
11-24-15 09:16 AM
runyonwc
IS F (2008-2014)
02-14-14 12:54 PM
bowen.chau
RX - 1st Gen (1999-2003)
11-28-10 01:36 AM
hkykat
11-06-07 05:51 AM
bigbllr2000
Performance
06-08-02 10:21 AM
Quick Reply: Engine dies after cranking. Will run w/foot on gas!
