PCV Valve where is it??
Old 06-26-06, 04:04 PM
CO-LS400
CO-LS400's Avatar
Default PCV Valve where is it??
Dumb question from a DIY>. Where is the PCV valve on a 2000 Ls 400..
Its probably right in front of my face but I can't seem to locate it..
Thanks
Old 06-26-06, 04:28 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
not 100% for that year but im pretty sure its under the engine cover on the driver side valve cover.
Old 06-26-06, 06:03 PM
CO-LS400
CO-LS400's Avatar
ahhh haaa.. I had to order the pcv valve.. once I see what it looks like I'm sure I'll find it.
I'll be looking on saturday!
Thanks.
Old 06-26-06, 10:49 PM
ntran18
ntran18's Avatar
Driver's side. It is the only thing on that V bank with a hose attached to it. You don't have to remove anything. Of this is off of an SC4, but I don't believe it's any different on LS4.
Old 06-26-06, 11:17 PM
PureDrifter
BahHumBug
Forum Moderator
il check my dads 00 LS to make 100% sure for you. been meaning to do that anyway.
ntran, unless the SC4 was a vvt-i motor'd car then it could very easily be different.
Old 09-24-08, 04:13 PM
lexie
lexie's Avatar
what about the location of 98 LS PCV valve ? When are we suppose to change it? IS there any write up? I know there is a write up for the 1st gen. LS.
Old 10-09-08, 04:09 PM
lexie
lexie's Avatar
Do I have to change the grommet when changing the 1998 LS400 PCV valve ?
Old 10-09-08, 04:32 PM
LiCelsior
Retired
LiCelsior's Avatar
yes change the grommet with it. trying to lookup the location but no prevail.
Old 10-13-08, 04:15 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
driver's side of the engine. Next to the oil cap. Just buy an OEM one and replace or clean up your old one with some carb cleaner.
Old 10-13-08, 10:34 PM
lexie
lexie's Avatar
I found it ! Thank you Grand LS4.
Old 08-09-09, 10:24 PM
valex
valex's Avatar
Default 1999 LS400 with 107K miles PCV
Today I changed the PCV on my `99 LS with 107K miles. Most likely it was the original one(i got the car with 38K miles). I was surprised that the old valve wasn`t much different in condition from the new part, no build up like on LexLS tutorial picture. The grommet was in a lot worse shape though, old rubber got brittle and i had to be extra careful not to drop anything inside the whole - the grommet broke into pieces as I was taking it out and I had to use both little long nose pliers and a screwdriver in the other hand to hold the breaking parts from dropping inside. The area around the valve was a little dirty - perhaps due to the grommet not being tight.
flux702
Performance & Maintenance
04-29-20 08:08 PM
MrDank757
01-09-18 03:52 AM
toyo
03-11-13 04:08 PM
decypher
08-22-11 09:30 PM
gs300_tx
GS - 1st Gen (1993-1997)
07-21-09 04:25 PM
Quick Reply: PCV Valve where is it??
