Need help on soundsystem, plz!
For awhile, we hooked up 2 jlw-3 + a performance tekniq amp (bridged) to the 1993 stock amp.
We used a high to low converter for the conversion. WE attached this to the previous stock sub for the lexus.
Problem is: whenever we turn off the sound system AND/OR shut off the engine, the subs "pop." I figure it has to do something with the power to the amp...but I don't know where to isolate the problem.
thanks a bunch guys
eKay
thanks a bunch guys
eKay
I had this prob,a while ago.When i first installed my JL's.
I took it to an audio shop and they said it could be because the head unit is stock or the ground is located in a bad place,but they solved the problem by making a kill switch for the amp.
I would just use the swtich to kill the power to the amp and then turn off power to the head unit.
johnnyboy
04-04-08 01:24 PM
