Power difference In gen1 vs. gen3
Old 07-04-05, 09:28 AM
sonbum1
sonbum1's Avatar
Default Power difference In gen1 vs. gen3
How did lexus get such a big power difference from the gen 1 LS to the gen3 LS? I think the hp's are 250 & 300 respectivly. I believe they are on the same block (1uz) there both 4.0 liters, and the exhaust doesn't seem any freer flowing.
Old 07-04-05, 09:38 AM
xirforever
xirforever's Avatar
I think the 3rd gen had VVT-i, that helps a bit.
Old 07-04-05, 11:32 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
The LS has 290Hp, not 300. Due to VVT-i, and the 5-speed Auto primarily, and other small improvements here and there.
Old 07-04-05, 12:19 PM
persian451
persian451's Avatar
its qutie a big difference as far as accelration goes.. i'm not sure, but the 3rd gen might be lighter.. i know the 2nd gen is compared to the 1st
Old 07-04-05, 12:41 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Thats true. Not sure what the orginal poster meant by Gen 3, 2001 the third+, and Lexus calls the 98+ third gens.
Old 07-04-05, 01:07 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
by third gen im asssuming hes reffering to the third bodystyle LS400 and not the UCF30/31 LS430s. so this is the 98-00 UCF21(gen 2.5) cars as compared to the early 89-94 UCF10/11(gen 1/1.5) cars.
now, the gen 1 cars had the same 4.0L 1uz block as the rest of the "400"s. but it made
250 hp @ 5600 rpm and260 ft-lbs. @ 4400 rpm. it also had a 4spd ect-i automatic trans.,
the Gen 2.5 cars had the same block BUT had Toyota's version of Variable Valve Timing - VVT-i.
this gave the gen 2.5 cars about 290 hp @ 6000 rpm and 300 ft-lbs of torque @ 4000 rpm. these cars had a new 5spd Automatic trans with ECT-i.
the gen 1 cars had a curb weight of 3759 lbs.
the gen 2.5 cars had a curb weight of ~3650 lbs give or take some.
hope this helps
-Annant
Old 07-09-05, 08:28 AM
sonbum1
sonbum1's Avatar
Thank you all who replied. I may have some questions on V V T I in a few days.
Old 07-09-05, 08:31 PM
gowest
gowest's Avatar
I think that VVTi boost torque and hp up alot at lower engine RPM. Anyone have pic of stock dyno chart comparision between 1st version and 3rd version UZ.
Old 07-10-05, 01:33 AM
sonbum1
sonbum1's Avatar
Ok.... V V T I is this somthing that is electronicly controled as in ECU or some other computer system, or is it mechanical, as say the cams/valves/springs? Basically is this a tuning thing that could be done by upgrading some hardware, or is this an enginering thing that requires computer/electronic sytem intergration?
Old 07-10-05, 05:33 PM
PureDrifter
BahHumBug
http://en.wikipedia.org/wiki/Variable_valve_timing
Hiroshi12
09-25-15 11:29 AM
rockroll
12-28-12 06:08 PM
no1gsxr
03-08-09 10:22 PM
Wald GS
GS - 1st Gen (1993-1997)
11-21-03 01:47 AM
healerhand
SC- 1st Gen (1992-2000)
04-25-02 08:03 PM
Quick Reply: Power difference In gen1 vs. gen3
