LS400 Radio Nak problem help
Old 01-10-05, 05:44 AM
djr73999
djr73999's Avatar
Red face LS400 Radio Nak problem help
Hello Gang,
Was looking to see if anyone has had this problem and if you would know a fix or not,
When I adjust the volume on the Nak radio, (have a 95Ls400)it seems to die out have a
fade in and out problem, anytime I turn the volume past the halfway point it just sounds
like a amp or speaker has been blown, anyone know what the symptoms would be when your
radio is going out? sounds really annoying, could it be the battery alt, etc. any suggestions
dj
Old 01-10-05, 01:12 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
sounds like an amp. Check your connections though to be sure.
Old 01-10-05, 02:31 PM
SharpLS-96
SharpLS-96's Avatar
Originally Posted by djr73999
Hello Gang,
dj
Quote from http://carstereohelp.com/lexus.htm
*NOTE - For Nakamichi, intermittent speaker output, loose of volume to some speakers? Our local dealership says there is an equalization unit located behind the glove box in need of repair, we have never seen or found one! What are they talking about? We have seen this to be a stereo or amplifier problem.
Most likely it's either the head unit or the amp which is mounted under the front passenger seat.
Old 01-10-05, 02:49 PM
hlovepenn
hlovepenn's Avatar
Check http://elliottelectronics.com/ They just fixed my '96 LS400 Radio after checking the Amp and finding nothing wrong. They are fast, reasonable and very nice to work with! Super service!
Old 01-10-05, 03:16 PM
aromack
aromack's Avatar
Question simular problem with fade.
I have noticed that my Sc400 pioneer radio fades the volume lower and loses some fidelity upon acceleration. However once i am at a stop light or still the radio regains volume and the fidelity of the system becomes much better and clearer. Anyone else with this issue at all?
Old 01-10-05, 11:29 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Have you tried turning off ASL if so equiped?
94lexus88
11-01-10 09:56 AM
robsvdp
01-29-10 11:14 AM
2Lexos
06-22-06 07:56 AM
mossnojoke
01-06-06 08:51 AM
kaidoy
01-27-05 04:01 PM
Quick Reply: LS400 Radio Nak problem help
