ABS & VSC code C1253
hi
when i drive my car ls460 , ABS & VSC and traction light coming on the bord ,,, some time disappear and after 3 or 5 days coming on the bord again .
i check by the computer ,,, i found this code C1253 which mean ( pump motor rely ) .
please anyone have any ides about this code or the location in the car .
many thanks in advance
Check your battery? I know dying batteries often throw random codes/lights sometimes.
Or if you recently changed your battery, it could be causing that too?
I'm purely speculating and speaking from experience with other cars...
This code relates to your brake actuator and it's inlet valve. I would start with resetting the code and see if it returns. You don't indicate what year your car is, and whether it may be under any warranty.
I check already , and i change to new one still problem coming.
please advise me ,,,,
I do reset but still problem coming
my car year 2007 .
it is not under warranty
please advise me wher is the brake actuator location ???? i will check and see
