Hybrid TechnologyUnique topics related to the LS600h L model hybrid drivetrain and other features/options found only on the LS600h. Please use the main 4LS forum for discussion about shared components with other fourth generation LS models.
Thank you, but actually I need length , width and height .
Trying to figure out if baby stroller will fit in the trunk.
It's not a perfect rectangle. But, it's 52 1/2" at the back of the trunk opening with a trapezoidal shape that narrows to 44 1/2" at the front.
Height is pretty consistent 21".
Depth is variable depending on where in the trunk you're measuring - from 19 to 25. The panel in the back of the trunk has a couple of bulges on the ends on the upper half. In the center it's about 25 the whole height (the lock bumpout in the the rear lip makes it not exact) but for the foot on either end it's about 22 from the lower half of the rear panel to the trunk lip but only 19 from the upper half of the panel due to bulges likely caused be some equipment in the back for the rear a/c.
I was looking into that whole issue when looking for a 600 and determined that pretty much any stroller should be able to fit. However, I did end up with a 460L with a short trunk, so it's probably worth double checking.
