No interior heat at idle in 2008 LS460L - Low coolant ??
Personally I've poured coolant right down into the bleeder port you are talking about...why not? Yeah I spilled a little, but I was doing a coolant change at the time anyway...it's not like things weren't a mess already. But I want to make it clear that I filled the reservoir up first, I just added coolant in the bleeder port to speed up the process of getting the air out. It worked fine.
Make sure the AC is off. Loosen the vent plug and add coolant to the reservoir until it reaches the full line and and when no more fluid can be added, close the vent plug.
Before starting the engine to warm up the engine, turn the A/C switch OFF (Which you should have already done above).
While idling the engine for approximately 10 minutes, make sure the coolant remains at the FULL line by adding coolant as necessary.
After idling the engine for 10 minutes, add coolant until it reaches the the base of the reservoir's filler neck , (which is the lower edge of the inner wall of the filler neck). Don't mistake this for the fill line....two different things.
Close the radiator reservoir cap, and run the engine at 1500 to 2000 rpm for 5 minutes.
Stop the engine and wait until the coolant cools down to ambient temperature.
CAUTION: Do not remove the radiator reservoir cap while the engine and radiator are still hot. Pressurized, hot coolant and steam may be released and cause serious burns.
Check the coolant level.
If the coolant level is below the FULL line, add coolant until it reaches the FULL line.
Roadfrog, thanks for posting all those procedures in post #18.
I hate to dig up an old thread, but I have a question regarding the no heat at idle. I have a 2014 460L (awd) UL and there is no heat in front or back at idle. Could it be caused by the same thing? All the cars mentioned in this thread are 08's. Once I start driving, everything is fine. I wasn't sure if this would apply to a '14 also?
That would apply to almost every car, there could be several reasons for low coolant levels but checking the reservoir should be your first step.
I agree with GERF. The procedure listed above is the same for your car. Have you ever had the coolant drained and filled in the past 50k miles? No? It's past due. The shop can also find your leak. The system is "sealed". The black plastic cap is supposed to be air/fluid tight. No evaporation at all.
What about the valley pan gasket? I was smelling a slight coolant odor when driving around. I drove from SF Bay Area to Pasadena with no issues but was told the valley pan gasket might be the issue. Opinions?
It's not easy to see/find, but, removing covers from engine bay and looking at valley area behind throttle body with good lighting may reveal pink residue. Also remove underside panels and inspect for pink stains to eliminate those places. Also the radiator nipple on driver side (hidden by covers) is another trouble spot. Don't guess without a visual inspection.
shinbo
03-03-19 01:34 PM
