DVD Formats
DVD Formats
Searched the forum but couldn't find anything (if such a question is already answered, just drop me a link).
I have LS with ML audio and I want to know if I can burn MP3s into DVD+RW discs and play music? I believe it should work (because it does read MP3s burned as data into CD-RW), but just want to be sure. If so, should I burn DVD+RW as a simple data disc, or select some specific format?
I create DVD audio discs on DVD-R discs and they sound really good. If you have the Mark Levinson system it can play DVD-Audio (which is different from the normal DVD-Video discs).
in my 13 car i have a place to plug in a thumb drive and you can play mp3s there. It is in the center console.
there is a after market product I saw here on one of the posts that a company sells a aftermarket product that allows you play mp3s also.. I forget but I think the company is Visio but I might be wrong.
I have a lot of DVD Audio. I use the Cirlinca software's DVD Audio Solo. They come out as DVD-A.
The advantage of mp3 on a DVD is that you could put tons of music on it. I have used it for the other end of the spectrum and downloaded high def (master grade) .flac files from HDTracks.
Taken from ML page:
https://www.clublexus.com/forums/gs-...ml-system.html
My Vaistech iViC can play MP3s and other formats via the USB connection. I have also played MP3s on a disc, but now i can't remember if it was a CD or DVD? Have to go back and look
Lexus supports DVD-A and DVD Audio Solo is a nice piece of software for burning the discs. However, it is high definition but Lexus plays stereo only. If you have 5.1 FLAC files you need to burn DVD-V to get the surround sound. Cirlinca installs a third party plug-in when you burn a DVD the first time.
Taken from ML page:
Taken from ML page:
Maybe Cirlinca is guilty and not outputting 5.1
At https://www.clublexus.com/forums/2546234-post7.html DrexLex says:
In addition, the ML system can play back only 2 channels of PCM from DVD-A. So don’t bother making any source files with more than 2 channels. If you have a source of 5.1 programming, then you’re better off making a 5.1 Dolby Digital DVD, or make a DTS CD. Both of those will play perfectly and preserve the discrete 5.1 quality.
This is the disc. I bought it on Amazon in 2012. However I don't see it up for sale anymore by Amazon.
I need to find the disc to check whether the files are in AUDIO_TS directory. It's been a while since I have played it. I originally bought it to prove to Lexus that the 2012 LS with the ML system was attenuating the bass when you turned up the volume. I did prove it to them, but they refused to do anything about it.
I have used Cirlinca HD Audio Solo to build a blu ray disc with 5.1 sound and that works on a blu ray player. I have not tried DVD Audio. Now you have me curious so I will download a 5.1 test track, burn it using HD Audio solo, and test it in my car.
Another thing: the post that you mention appears to be for the ML system in the GS. I believe those systems are the Premium Systems. The LS has a Reference system. Maybe it can play 5.1 DVD Audio.
Amazon.com: Sonic Boom: Music
Here is a test iso for your car: DVD-A DVD-V
Same source, 5.1 FLAC, and DVD-A is stereo only. I tested it on my 2008 LS600 RSE system.
It is time for a write-up how to exchange a Lexus DVD player by Bluray. Is there anybody out there to do this? Either the rear seat entertainment player or front. Replacing the unit is not possible as it is an integrated part of the audio/video system. It is about the capability to read Bluray; maybe exchanging the laser and mechanics can do the job.
