08 LS 600HL rattle noise behind nav screen
Old 08-01-13, 12:53 PM
lexus600hl
lexus600hl's Avatar
Default 08 LS 600HL rattle noise behind nav screen
On occassion, I have had rattle noise coming from above the radio and behind the nav screen.
Has anyone had this same issue? It is not repeatable - hence the dealer was unable to fix it.
Solution?
Old 08-05-13, 10:47 AM
RodT
RodT's Avatar
I haven't experienced that with mine but i will definetly pay attention to see if i hear any rattle the next time i drive it.
Old 08-05-13, 08:11 PM
CJITTY
CJITTY's Avatar
Yes..there is a TSB on this. I had my rattle resolved but it requires the whole dash to come out with major surgery and replace with different clips that can handle the additional weight that the 600 leather dash has. One resolved, it like night and day for the better of course
Sent via Club Lexus Mobile App
Old 08-18-13, 07:26 AM
lexus600hl
lexus600hl's Avatar
I left it with the dealer for a week. They took it out several times and could not reproduce the sound.. Then they said that they found a rattle somewhere in the dash and fixed it.. but they did not do the TSB you mentioned.. which is a good thing because I dislike for them to pull out the entire dash.. Often, they can't put it back together well enough!
Old 08-18-13, 08:52 AM
RandyV
RandyV's Avatar
Here are the referenced TSBs:
http://www.lambros.net/LexusTechInfo...L-NV011-07.pdf
http://www.lambros.net/LexusTechInfo...L-NV005-07.pdf
Amy qualified Lexus Dealer should be able to do this repair without creating additional problems. You could do it yourself if you know your way around a screwdriver.
Old 08-18-13, 08:57 AM
lexus600hl
lexus600hl's Avatar
The links to PDF didn't work. Could you please repost the links? Thanks.
Old 08-18-13, 09:04 AM
RandyV
RandyV's Avatar
Try them again - they should work now.
Old 08-18-13, 05:03 PM
LXurious
LXurious's Avatar
A car past the initial warranty cannot get this covered?
Old 08-18-13, 07:26 PM
lexus600hl
lexus600hl's Avatar
Thanks! Got it!
Old 03-26-14, 08:38 AM
preamm
preamm's Avatar
Solution?
I have a dashboard noise problem in my LS460L. Dealer diagnosed it as a cooling fan malfunction. This requires the Navigation screen to be pulled out and rebuilt. Yes, rebuilt, even though the system is still under warranty the dealer does not replace with a new one but rather a rebuilt one While waiting for the rebuilt to be completed I can drive the car but it seems that all systems controlled by the touch screen are, of course, not working. Dealer says it could take up to 30 days for the rebuild. It's cold in Minnesota in March, I need a working climate control system.
Old 03-26-14, 08:42 AM
preamm
preamm's Avatar
Default LS460L Scratchy noise from behind Navigation system
Old 03-26-14, 11:08 AM
CJITTY
CJITTY's Avatar
Dammmm that sux
kwu
01-31-11 03:57 PM
GSLA
10-31-10 01:29 AM
gpb
08-21-09 08:01 PM
Avid1
04-11-07 11:48 AM
Quick Reply: 08 LS 600HL rattle noise behind nav screen
