HELP!!! Interior dome light trouble...
Sorry guys for the delay but I don't have any good news. I could not get the rear dome to work. Tried flipping the bulb, etc. Nothing. I kind of gave up. The front dome is so bright that I'm just going with that for now. Maybe I'll stick the stock bulbs back in and take it to the dealer and play dumb.
Did you get a solution to this one? I am having an issue with my driver and passenger courtesy lights not working. 07 LS. During a change to LED lamps I pulled the original bulb out and inserted the led lamp and it would not light. I tried rotating it 180 for polarity and that was no help. The led is very dim. When I put the incandescent bulb back in there is light. Bought new incandescent lamps and the same thing. Can't believe a fuse would be causing this issue. Can't locate the fuse either? Any help would be appreciated.
Note that my passenger side is working fine with the LEDS
No, my original bulbs worked fine. Problem surfaced after I installed LEDs. Now the LEDs or original bulbs are not working for front courtesy lights only. Rear doors work fine. When I have some time, I will identify fuse and see if it is a problem.
My drivers door and passenger seat behind drivers door no longer work. There is power but not enough to fully light the LED lamp and there is nothing with a regular bulb. Read through the manual and I'm not clear on fuse or fuse location?
Did you make sure you bought 12V LED's?
There is some useful information regarding door jamb switches at this location: https://www.clublexus.com/forums/ls4...rning-off.html
You may be experiencing a bonding/corrosion issue and torquing the door-jamb-switch mounting screw may solve your problem. The corrosion issue is mentioned in the thread that I cited above.
I am not aware of a TSB for the door jamb switches. If anyone have information about that please let us know.
Replace the door jamb switch earlier today. Didn't work.
