corner light bulb swap
Old 05-09-16, 08:16 PM
  #241
ls460v12
ls460v12's Avatar
Default thanks, just did mine to white LED
Just get some new 10mm and 7mm plastic fasteners also to put your engine compartment shields back in like new, cheap on amazon or ebay.
Old 09-01-16, 04:05 PM
  #242
Tantrix
Tantrix's Avatar
don't mean to bump up a old thread, Im assuming this will function same as the park lamps.
is there any we can function this as a DRL ? is it possible to put the drl bulb socket into the swoosh pattern socket ?
Old 09-01-16, 04:21 PM
  #243
Shibumi1
Shibumi1's Avatar
not exactly.. the drl is also the high beam. only dimmed thru pwm (pulse width modulation) but u wire the Nikes as drl's by linking them to the ign circuit (i used fused relays)
last pic was with my old bulbs.. 1st 3are with my new bulbs
Attached Thumbnails corner light bulb swap-20160901_191615.jpg   corner light bulb swap-20160901_191645.jpg   corner light bulb swap-20160901_191830.jpg   corner light bulb swap-20160901_191941.jpg
Old 09-30-16, 08:11 PM
  #244
Kevinls460
Kevinls460's Avatar
Thanks Shibumi, after reading this post, im able to get it done . It's great for now.
Old 10-02-16, 06:34 PM
  #245
Shibumi1
Shibumi1's Avatar
great... glad to help
Old 10-02-16, 10:00 PM
  #246
Kevinls460
Kevinls460's Avatar
I use this, kind of bright but i think it's a bit bluer compares with stock head light. Maybe i have to use 5k for the best match next time if those burn out.
Old 11-30-16, 12:13 AM
  #247
bossrek
bossrek's Avatar
Hi
I just bought new 2007 LS460
I am about to change the nike corner
can you please help me to chose the best and suitable led , I need your experience
thank you
Old 12-06-16, 05:15 PM
  #248
PhatDad
PhatDad's Avatar
Originally Posted by bossrek
Hi
thank you
This thread has tons of good information. I can't remember which ones exactly but it was what was discussed in here. Probably the ones that were discussed towards the end are the latest and best ones. GL
Old 12-07-16, 07:56 AM
  #249
CRowe14
CRowe14's Avatar
Hi
thank you
Hey, congrats on the purchase!
Yes, as PhatdDad stated, the lights that Kevinls460 used should work fine, especially if you desire to go with the easiest, most straightforward route, without wire splicing, taping and adhesives. A 194 LED would be the way to go.
Good luck!
Old 12-10-16, 11:28 PM
  #250
bossrek
bossrek's Avatar
Thank you guys for greeting my new purchase
i am searching for the 5000K as Kevinls460 stated in his post
I found this pair at amazon
What do you think is it good ?
Please advise
Old 12-12-16, 11:25 AM
  #251
FreddyG
FreddyG's Avatar
Please advise
Be careful of DDM Tuning products. They are reasonably priced, but I bought a set of HID lights from them to use as fogs and when I plugged them in, one didn't work. I tried to get in touch with them to warranty it and had some problems there too. By the time I'd have paid shipping back to them, it wouldn't have been worth the cost. I cut my losses and wrote it off as a learned lesson on my part.
I've found that when buying lighting products, it's better to pay a bit more up front and get a better quality piece (and I'm cheap, so I don't say that lightly ).
The saying Caveat Emptor (Let the buyer beware) comes to my mind when dealing with them. I'd pay a bit more just for something proven just for the fact that it's not a piece of cake to change these bulbs.
They are advertised as being Cree's though and they are good led's, but I just don't have much good to say about DDM Tuning.
By the way, DDM does sell some nice Lexus valve stem caps for a good price and they worked great.
If you buy them, Please let us know how they work out.
Old 12-12-16, 12:27 PM
  #252
kingbabar
kingbabar's Avatar
Do the '13 LS F Sport use the same bulbs? (asking ahead for reference)
Old 01-06-17, 09:54 AM
  #253
LexlugerA
LexlugerA's Avatar
Default Where to purchase bulb
Originally Posted by CJITTY
MotoringMax on fleabay...here is a pic of an LS with the White 38-SMD 2825 LED Position Lights
where can I purchase the right bulbs that will last and won't burn out quick ?
Old 01-27-17, 11:34 AM
  #254
JH48
JH48's Avatar
Is this the same as 2010 headlights?
Old 03-02-17, 12:25 AM
  #255
PMD008
PMD008's Avatar
Originally Posted by Shibumi1
i did it without removing the whole bumper.. remove the grill (1) 10mm socket. the remove the plastic clips holding grille on each corner.then its easy as pulling the grille forward gently as u release the locking tabs (4).. once the grille is out you'll see a plastic trim w foam tucked behind the bumper trim on either side of the grille opening.bend it down then you'll see 2 wiring harnesses unclip them or bend the metal tabs holding them in place an you'll see the bulb socket reach in an turn it counterclockwise an pop the socket out.
Found your post on this today. I had some difficulty with the driversl side (passenger in US and mainland Europe) but your first explanation was excellent. I could have benefitted with GI Joe sized hands however! I put in LED's with a focused forward beam and 10 around the sides, Looks great in the dark, thanks again.
Quick Reply: corner light bulb swap
