Adjusting Datasystems controller in LS460L
Old 01-05-08, 10:48 AM
12volt
12volt's Avatar
Default Adjusting Datasystems controller in LS460L
Guys,
I picked up a controller from another member that had 3 presets. However the driver side sits about .5-1" taller than the passenger side. Since the instructions are in Japanese...how can I adjust or change the settings.
Any help or manual would be great.
Old 01-05-08, 08:19 PM
rominl
exclusive matchup
rominl's Avatar
you click on the bottom left button, it will go to the "change" screen where all 4 corners flashing. if you press the bottom left button again, the top left (front left) will flash and you can adjust that. then the front right, then the rears (rears can't be adjusted individually), and then it cycles
once you are done, click the top left button to memorize
Old 01-06-08, 07:49 AM
CEOEngr
CEOEngr's Avatar
Help! what is a Data System controller???
Old 01-06-08, 08:09 AM
Gojirra99
Super Moderator
Senior Moderator
Gojirra99's Avatar
The Data System controller is for lowering the LS460L with air suspension.
Old 01-06-08, 08:27 AM
CEOEngr
CEOEngr's Avatar
Thanks. I get it ..... it is a after market mod to LS's with AS.
Old 01-06-08, 09:35 AM
rominl
exclusive matchup
rominl's Avatar
yes, it's an aftermarket controller that you tap on the oem ecu to lower the car. there are different settings to allow you adjust the height
Old 01-11-08, 12:51 PM
12volt
12volt's Avatar
Thanks Rominl....I just got back from the CES show and will try to modify the setting tonight...I wonder if I just accidentally adjusted the preset it had before I knew what I was doing.
Appreciate the help.
Old 01-11-08, 01:01 PM
rominl
exclusive matchup
rominl's Avatar
it should show the settings at all 4 corners anyway so you will know
Old 09-30-08, 09:26 AM
rueym
rueym's Avatar
where can i buy a datasystems lowering module for the ls460L?
Old 09-30-08, 10:37 AM
rominl
exclusive matchup
rominl's Avatar
you can email chung@prestigioussociety.com
that's where i got my unit from
Old 09-30-08, 10:20 PM
rueym
rueym's Avatar
thanks for the quick reply. i'll check with them now.
CJITTY
07-06-24 02:46 PM
clammbo
11-07-21 04:46 AM
FoxCars
12-30-20 05:15 PM
junjdm
07-03-09 01:32 AM
mhenrey
11-14-08 04:03 PM
Quick Reply: Adjusting Datasystems controller in LS460L
