ECU reset - which fuses...
Hi guys,
I want to do an ECU reset to get the car to re-learn my driving style rather than the previous owners.
I've done a lot of searching and it seems the EFI and ECTS fuse pull is my best option. I have established I have what the manual refers to as a "TYPE B" fuse box, and I think I have worked out the set of fuses I need to pull - see pictures attached.
Has anyone done this before and does it look like I've identified the correct ones?
This is news to me. I wasn't aware that our cars had the ability to learn our driving styles. Exactly what parameters reflecting our driving are stored and used? I thought the engine CPUs were programmed by Lexus according to their research into vehicle driving dynamics, road conditions etc.
I know this trick works on older vehicles, but my understanding is, that our LS's are constantly re-mapping to your driving style. If you've driven your car for 200 miles or so, it's already adjusted to your driving style. If you're determined to reset, the easiest way is to just disconnect the neg terminal on the battery.
I was aware that the new G90, MB S-class and BMW learned your driving style and adjust accordingly. What ever that suppose to mean but I wasn't aware of any LS's doing so.
The LS does it although a bit slower than other cars. One way to test how quickly it adapts is to step on it for one day that you have a few errands to run. You'll notice by your 3rd or 4th trip (short trips, mind you) the car would have re-adjusted to holding revs longer for example - it's very apparent. Funny thing is it "learns" slower (easy gradual take offs for example) driving much quicker than stepping on it.
I'm surprised there's no reset procedure for the LS though? Most cars compound the data to find the happiest medium and sometimes it's better to just start a fresh.
Believe it or not, first I heard about ECU learning was when I purchased ES in 2000!. At that time I was told it primarily uses to manage fuel efficiency based on drivers driving habits such as hard/slow accelerations, braking,, transmission shifting etc.
I am certain that Lexus/Toyota would've advanced that feature on newer models. But not much information from Toyota/Lexus could be found. Since our cars have almost become semi automate, I am sure ECU learning would track speed, wind resistance, rolling resistance, steering etc to predict and adjust fuel and transmission systems and eventually provide a enjoyable driving experience. They could've gone further to integrate with pre-collision system etc.
If more than one person to drive the same car, based on driver seat presets or key cards it could tracked and learnt. It is doing?. I don't know. If any one works or knows someone who works at Toyota/Lexus may be worthwhile trying to find these details.
If I remember correctly, Oliver Enterprise (aka 7milesout) worked at Toyota in design. Jason, any input?
