what floor jack or lift to use for LS460
Wonder what floor jack or lift do you guys use when working on the LS460,
seems it has to be a low profile jack to go under the car to the jack point in the front,
The jack i have is the "4 ton Steel Heavy Duty Floor Jack with Rapid Pump", which can only be used to jack up the car on the side behind front wheels.
http://www.harborfreight.com/4-ton-s...ump-68056.html
for a low profile floor jack, I'm considering:
2 ton Low Profile/Long Reach Steel Heavy Duty Floor Jack with Rapid Pump
http://www.harborfreight.com/2-ton-l...ump-68050.html
or:
3 ton Low Profile Steel Heavy Duty Floor Jack with Rapid Pump
http://www.harborfreight.com/3-ton-l...ump-61253.html
which one to choose for the LS460?
Thanks for your input.
or:
Personally, I own the 3 ton low profile jack.
Obviously the lo-pro is needed because this car sits relatively low to the ground.
I purchased mine from HF back in 2014 and have never had a problem with it.
Works great and jacks the heavy LS with no issue what so ever.
To jack up the front end and lift both tires simultaneously, I place the jack plate directly below the cross member area, then place my stand in the appropriate locations behind the front tires.
The 2 ton looks great.
What really sold me on the 3 ton at the time, was that I happen to catch it on sale for $74.99, great deal for a great jack.
Kevmo707 (12-27-16)
Thanks a lot for the input, that sounds great, guess I'll get the 3-ton low profile floor jack.
HF is having a 25% sale now, so the 3-ton floor jack is on sale again for $74.99.
For certain things HB is a great store.
I think you'll be pleased with the jack.
Its really heavy duty and works great.
The HF yellow 3 Ton Daytona jack is the best built car jack they have, I have seen this jack in person and it is a heavy duty jack that can stand the heavy use.......This is NOT a light weight POS jack and they compre it to a Snap On floor jack.
Harbor Fright quality has gotten better over the years but always check the product reviews before buying anything from them. I have owned a Hein Werner floor jack for years and I highly suggest checking them out if you want a commercial quality floor jack that is rebuildable and will last a lifetime.
TIP! Make sure you buy and always use properly rated jack stands.
BTW! I hate to break the news to you, BUT..... You can't use the HF 20-25% off coupon for floor jacks. READ the fine print. This is how they suck you into the store. My suggestion is to wait for them to put the jack on sale if you want to save some money
Thanks a lot for the information and suggestion.
Now i remember that those coupons can not be used on floor jacks.
The Daytona jack looks great, but not sure if it is a low profile jack,
Sometimes even a low profile jack doesn't get to the "jack spot" you want it to...... Just grab some 2x10's and drive the car up on them to gain a few inches under the car and you can use any floor jack. This is how I jack up my Dodge Charger SRT that is much lower than the LS460.
that's good idea, this way maybe even my 4-ton floor jack can reach the jack spot.
or maybe just build car ramps with 2x10 lumbers.
get long reach jack
just make sure the jack has a long/deep reach to minimize jack handle contacting the front bumper during initial pumps ; I am still using a heavy jack bought 15 yrs ago - not sure but I think its 3 ton ; its heavy and not low profile but it works. I custom cut a square piece of 2x4 wood placed on jack before sliding it under the car.
Tried to use my low-profile racing jack today to put on my winter tires for the first time. The front was no problem; however even with looking at the owner's manual I couldn't locate the jack spot in the rear. Ended up using the supplied Lexus jack and doing one side at a time. Seemed to be rather hard to get to; it's way under there!
I know that some use the differential to jack it up, but I just didn't feel that placing so much stress on the diff case would be appropriate.
I wont act as though I am an expert at this, but I just took the "known" route regarding how to jack up the car and proceeded with the brake pars replacement, using jack stands for stability and safety of course!
Same issue here. I need to use the high mode on the air suspension to get the jack in place.
On a prior car (Mazda RX7), I had two thick rubber plates that I drove up onto.
As I stated above, I had always been weary about using the diff as a jack point.
Thanks for the clarification once again Chris.
