View Poll Results: Regular, Mid-Grade, or Premium?
Regular
10.00%
Mid-Grade
0%
Premium
36
90.00%
Voters: 40. You may not vote on this poll
Gas: Premium vs. Regular advantages, disadvantages (merged threads)
#211
I'm sorry, maybe i've jumped in a little deep here, but i know that on my previous car (LS430) that this was not the case, and was told by a local shop that the fuel delivery components would have to be modified.
From what i understand as well, this fuel would need a different engine program/tune, and that E85 is usually combined with a high compression engine.
When you say you know guys who are using it, do you mean on an LS460??
#212
Higher octane fuel allows a higher compression level before knock occurs. Once you determine the octane level that prevents knock occurance, using any fuel with increased octane level has no effect on increasing engine performance. You would have to increase the engine compression level to have any additional performance, i.e., rework the engine to have a higher compression.
#213
Guest
Posts: n/a
Wow 29k views on using gas for a flagship LS. Mind blown Over the years here we have had every gas thread possible and there is never an end, just people backing their thoughts on regular vs premium. The battle wages
No matter what you use, the V-8 guzzles, that is for sure!
#214
Most all automobile manufacturers recommend against using E85 (unless the car is a Flex-Fuel car). Don't know why, but it's there in the owner's manuals. Originally, ethanol was frowned upon because it degraded rubber fuel lines (mostly in boats, lawnmowers, etc) and absorbed water (in engines that sat without use for long periods of time). Being a boat owner, I know that the majority of boats built over the last 10-12 years can now use gas containing up to 10% ethanol, but not 15%. Go figure.
#215
#216
#217
at 12:1 compression ratio (technically 11.8:1) I won't even bother with it and put in premium, even though I'm at high altitude where gas starts at 85 octane and is ok for normal non-premium vehicles (87 required) to run 85 because of lower atmospheric pressure.
It's not about which octane is a better gasoline, it's about letting the engine perform as it was designed. Yes the engine does have revisions in place to run lower octane fine, but I would rather those systems be inactive and allow it to operate as designed.
don't get confused by the octane number, they mean the opposite. lower octane gasoline has actually more energy, hence why it is more prone to detonation (fuel exploding prior to spark plugs light off = wrong time for ignition), but it does not mean you get more power running lower octane. More power is harnessed by increasing engine compression ratio (either with increased piston stroke or forced induction).
#218
You should have posted that response in the combined fuel thread Persocon, but supporting some of the ideas of E85 ethanol fuel, Koenigsegg's website speaks to this on their CCXR: "When running on petrol, the 4.7 liter twin-supercharged Koenigsegg engine delivers 806 Bhp. This already-impressive figure rises to an exhilarating 1018 Bhp when the car is run on E85 Biofuel."
#219
For what it's worth
For what it's worth, my wife and I attended sort of a new car seminar at the Santa Fe, NM dealer recently as we have bought a new 2014 LS460L and a new 2014 RX350. When we walked into the work bay area they had a guy there to discuss gas. He specifically stated that it was OK to use regular gas at our altitude (about 7,000). Regular octane in Santa Fe is 86. We were both shocked, expecting that he'd tell us tell us premium or 93 octane. He said you just don't need the high octane at our altitude. He did suggest that we buy premium on a planned road trip to Texas. So we started with 86 octane and then topped off the tank with 93 octane in Amarillo and for the rest of our Texas trip. All I can say is, both our cars work fine on 86 octane in Santa Fe.
As an aside, he also said that Sam's Club sell crappy quality gas. He had for display several clear containers of locally purchased gas. The Sam's Club one supposedly didn't look so great. I have bought Sam's Club gas for my Chevy trucks for many years and never had a problem. So now we don't hesitate to buy Sam's Club 86 octane. I'm not representing myself as any sort of knowledgeable person but both car seem to operate the same whether we use premium or 86 octane.
#222
Thanks everyone. So it looks like the consensus from an admittedly small (and possibly biased) sample is 10% regular, 90% premium. I've been through half a dozen tankfulls of regular since starting this poll. Everything seems fine; hint of lightly worse gas consumption but will need more miles to confirm.
#223
Kills me that these cheap azz folks buy a premiun car that calls for premium fuel and they want to save a couple bucks with cheaper fuel...comical. I wonder if these same folks rub their tree air freshner on their $45 suit for cologne too..you know..cuz its cheaper
#224
lmaooo this is too funny but i feel ya, its simple premium vehicle=premium fuel,its a 1:1 ratio
