Has anyone replaced the LOWER engine shield?
Old 01-05-17, 09:16 AM
Nphoops
Nphoops's Avatar
Default Has anyone replaced the LOWER engine shield?
My engine shield lost a few screws and came loose. Now it is cracked. Has anyone replaced this? I found the replacement shield but I am curious about the fasteners and getting it on correctly.
This is for the large black shield under the front of the vehicle.
Old 01-05-17, 09:55 AM
jimbosr1
jimbosr1's Avatar
i remove this before,very easy.
Old 01-05-17, 11:00 AM
Gronemus
Gronemus's Avatar
Taking it off and putting it back on is easy but time consuming if you don't have a cordless driver since IIRC there are 16 fasteners that need to come off. One of the things I noticed when I removed mine for the first time back in November was that the nylon threads in some of the retaining "nuts" on the frame were starting to strip. Sorry but do not know the part number of the fasteners off hand...
Old 01-05-17, 11:13 AM
Tom57
Tom57's Avatar
Easy to replace. Generic, non-OEM, less expensive are available.
Old 01-05-17, 01:54 PM
911LE
911LE's Avatar
I don't even run one on my car. I never installed it after my head gasket replacement.
Old 01-05-17, 02:05 PM
Scootymad
Scootymad's Avatar
I took mine off and threw it away. Helps let the heat out when I'm on the burnout pad :P
Old 01-06-17, 08:35 AM
BradTank
BradTank's Avatar
Several of those plastic underbody panels on my car have been coming off lately for me, usually on road trips. Just age seems to make them crack around the bolts where they are secured to the body.
Once one of them flies off, expect others to follow shortly. I was able to get some larger rubber washers at the hardware store and secure it on there. Seems to have held up so far, it's been several months.
Old 01-06-17, 08:50 AM
Johnhav430
Johnhav430's Avatar
It actually helps at 160 mph....j/k I know the vehicle is limited to 130. Maybe the .26 cd goes up without....
Old 01-07-17, 08:22 AM
Nphoops
Nphoops's Avatar
Yes, the one I found was very inexpensive with fast delivery thanks to Amazon Prime.
Old 01-07-17, 08:54 AM
2KHarrier
2KHarrier's Avatar
Link for future searches? Glad you found a replacement
Old 01-08-17, 11:45 AM
Nphoops
Nphoops's Avatar
Here's one: https://www.amazon.com/Perfect-Fit-G...eld+ls430+2003
2KHarrier (01-10-17)
Old 01-08-17, 12:52 PM
Johnhav430
Johnhav430's Avatar
cool, that p/n leads to the Toyota diagram that has p/n's for all the fasteners.
http://www.lexussouthatlantaparts.co...144150080.html
I actually have a bunch of different kinds, though only 3 of the most common in the engine bay. Tried to order 32 and the dealer came back with a Hall and Oates (No Can Do).
Old 01-09-17, 07:43 AM
Tom57
Tom57's Avatar
Less expensive front lower shield available at Auto Parts Warehouse & Rock Auto. Different size shields / part numbers for '01 - '03 and '04 - '06.
crazydrive
03-23-21 04:00 PM
ujusts
04-16-18 11:29 PM
ThumperPup
ES - 5th Gen (2007-2012)
09-09-13 05:23 PM
SlickRSM
09-18-09 08:21 AM
sam430
05-06-09 10:56 AM
Quick Reply: Has anyone replaced the LOWER engine shield?
