Oil fume smell
Oil fume smell
I've noticed that periodically I can smell oil fumes in the interior of my car. It's far from constant or intolerable. I have 122,000 miles and both Valve Cover gaskets were changed with in the last year and the engine compartment and floor are dry of any oil. Are there any other vulnerable parts that need to be examined or changed? Is there a PCV valve in our cars that can be a culprit? Any suggestions would be greatly appreciated.
Did you put any silicone on the rear semi circle plugs when you did the valve covers ? The factory service manual says to use some where the plugs, head, and valve cover gasket meet. You could have a small leak in the back and not see it.
Remove the two 10mm nuts and pop the engine cover off and check that the PVC valve grommet is not worn and leaking. While you're at it, check that the pcv valve is working as it should. When you give it a shake it should rattle easily. If not clean and check the operation of it using the process below. It can leak and travel towards the rear of the motor. That was a source of a leak on my car. I found the pictures below showing the location on the web.
Thanks Brewmyown for the info. I took the cover off and looked at the location. It's a little tight in there and I feel since all the hoses are very old and dry, if I remove them and check the valve I might have to replace the hoses and/or replace the valve. I do see that the PCV valve is not sitting flush to the grommet on the valve cover. Not sure if that might be the problem or the grommet is brittle and has play. I decided to leave all alone for the time being and see if I could pick up a new PCV valve and grommet before I proceed. I did give my independent all the grommets needed when he replaced the valve cover gasket last year, but I don't have total confidence he changed them. I won't take a chance of replacing the PCV grommet for fear it might break off and fall inside the engine..
Last edited by MRLexus90; 02-01-16 at 10:30 PM. Reason: added FSM torque specs page
All Valve cover bolts are loose after this many miles. Mine were too when my Valve covers were leaking. I did tighten them but after a short term it started leaking again. There are number of posts about this. Be assured it's not a short cut to replacing the valve cover gaskets. Old is old and they will need replacing as well as all the grommets and spark plug seals.
I have a 01 Base, Currently have 216K on the clock.
I could smell the oil burning a couple of months ago, each valve cover bolt was only finger tight. Tightened them all down, Oil burning smell is now gone. It will be interesting to see how long that just tightening up the valve covers will last....
dbui
RX - 1st Gen (1999-2003)
06-03-15 05:37 AM
