Coil Spring Conversion vs Coil Overs?
Which would be the better way to go? I want a nice firm (not harsh ride), improved handling over air, and I don't want to pay for air replacement.
I have been told Strutmasters or Bistein coil overs. N=Both seem to have advantages.
Feedback please.
Feedback please.
The only good coilover for the LS430 is the RSR units. They are Japanese manufactured specifically for the LS and are wonderful. The stock Lexus struts are actually KYB units. If you just want to lower the car slightly you could go that route and as set of Eibach lowering springs. The coilovers will give you the most adjust ability, however, they are around $2000.00 for the RSR Black I series.
Steve
Steve
So if i get non sport shocks and springs for a sport i will get a smoother ride. I think the ride is to stiff for me. I have owned 3 other 430's non sport and liked the ride better. If someone tells me there is not much difference between the 2 i strongly disagree.
Bilsteins are going to be a harsh ride.
Factory steel springs with KYB struts will be firmer than stock but not harsh and probably what you're looking for.
Also, the larger rear "Sport" sway bar is a nice handling improvement that's cheap and easy and will probably do more to give you better handling than other more expensive options.
I really don't think it's worth trying to make the LS into something it's not with a really firm suspension. It's just never going to be a sporty car.
Have you had Bilstein B14 before? Have you had any Bilsteins and on which vehicle? There is a difference between B. HD and B. Sport. Which ones did you have? Did you mix B. and aftermarket springs? Which springs did you use with the B. shocks?
