Occured WHITE noise after install "YATOUR YT-M02"
Dear Sir.
My LS430(2001) is not support mp3 and AUX
So, I'm buy the YATOUR YT-M02 from aliexpress.com. And installed to my LS, last weekend.
But occured some problem. occured WHITE noise.
Audio Select is FM radio.(not select CD)
Key is ACC
1. connect yatoure to my audio
2. occured reduce sound volume. But not occured white noise
Key is ON
1. occured WHITE noise(Bee~Eee~See~). but little bit.
Key is START
1. If step on the accelerator pedal, The WHITE noise is increase.
2. If step off the accelerator pedal, The WHITE noise is reduce.
I don't know why occured this problem to me.
Please advise to me.
Thank you.
Key is ACC
Key is ON
Key is START
Thank you.
I don't have first hand experience with the product you have described.
But make sure you don't have anything else plugged in into the 12v outlets, as it will distort the frequency on your device. Things like phone chargers, radar detectors... etc. Just remove everything from the 12v outlets and give it another try.
IF that doesn't work, hope someone here would have first hand experience with the device you are describing.
5150evh
08-05-15 09:04 PM
