Check Airconditioner...
hi
i recently had a problem with the AC on my 02 LS430,found out it had blown the AC ECU.I did the following.
1 . Changed the AC ECU
2 . Changed the compressor which was jammed.
3 . Changed the condenser as it had sum serious amount of residue in it.
4 . Changed the pressure switch.
5 . Changed the automatic temp control and other fuses.
AC up and running but then the problem arose,i get a CHECK AIRCONDITIONER message on the display and simultaneously the air flow changes from interior recirculation to fresh air from outside and the AC button starts flashing,it doesnt stop cooling though.
could u guys shed sum light on what could be the problem.
Thnx
Thnx
chrisindub
Performance & Maintenance
35
07-08-12 03:35 PM
