HELP Mystery electrical gremlin in my 06
I have an 06 with 96k miles, and out of nowhere my IOD (ignition off draw) functions all stopped working. This means my steering wheel doesn't move when i shut the car off, mirrors dont fold, key fobs dont work, smartkey system doesn't work, dome lights dont work, compass doesn't work, information panel doesn't work, trunk motor doesn't work, etc. When a door is opened or closed, traction control shuts off, vsc shuts off, the red triangle warning light sometimes comes on. All lights can be reset by turning the car off and back on. I discovered by accident that I can activate the warning lights and sometimes even reactivate ALL SYSTEMS by pushing the domelight buttons a bunch of times. It makes no sense to me.....I have tried swapping batteries with a new one, new keyfob batteries, checking for an IOD fuse (couldn't find it), and consulting a friend who is a mitsu tech (baffles him). Any help would be appreciated, I don't want to take the car in to a dealership and get murdered on labor cost for them to tell me its a bad fuse. Thanks!
The car is perfectly drivable, albeit sans any cool features...almost like safemode. I have to insert the keyfob to start the car, and can't lock it unless I use the emergency key in the fob.
Yea unfortunately leak/corrosion is what I thought of first.
Sometimes fuses relays ecu pcm components just come flawed when that happens unfortunately only way to know is to check everything individually.....I would really lean towards a relay though
thyshallsm
GS - 1st Gen (1993-1997)
01-22-15 04:12 PM
