Rear door lock question.
Old 03-28-12, 06:47 PM
Slvr surfr
Slvr surfr's Avatar
Default Rear door lock question.
Does any of your rear doors unlock automatically when the latch is pulled as the fronts do or do you have to unlock them manually? Mines dont. Is there something im missing or is this a S.O.P?
Old 03-28-12, 07:05 PM
Silkky
Silkky's Avatar
Hold lock and trunk button on the key fob until you hear 3 beeps. All 4 doors will unlock when you reach inside the handle.
Old 03-28-12, 07:19 PM
Slvr surfr
Slvr surfr's Avatar
Sorry i may have written this wrong way. I meant the inside rear door latches. My rear doors don't auto unlock the door like the fronts do when i pull the latch to get out.
Old 03-29-12, 04:57 AM
chunkyda
chunkyda's Avatar
My 2005 LS needs to be unlocked in the rear by something other than the silver door handle from the inside.
The front silver handle will perform the unlock function in addition to the open function.
Old 03-29-12, 10:23 AM
Silkky
Silkky's Avatar
Oh, I need to manually unlock the rears after I stop. Is it possible to unlock all 4 when you put it in park?
Old 03-29-12, 12:20 PM
Gene01
Gene01's Avatar
Is it possible that you have the rear door child locks engaged?
Open the door and look at its rear edge surface. If the small lever is in the UP position, the inside door open handle will be inoperable.
Old 03-29-12, 04:21 PM
Forbidden
Forbidden's Avatar
I was thinking about the same thing with the child lock
Old 03-29-12, 07:30 PM
Slvr surfr
Slvr surfr's Avatar
Yes the child locks are off. I can still open the door but only after i flip the unlock thingy with my finger. With the front doors all i have to do is pull the silver latch to open the door. Oh well i guess this is part of the design.
Old 03-29-12, 07:35 PM
AlexusAnja
AlexusAnja's Avatar
No, the rears will not unlock by just pulling the inside handle. Does not matter if child safety off. You have go manually unlock then open.
Old 03-30-12, 07:27 AM
kg19989
kg19989's Avatar
yep... I am not sure I have ever been in a car where the back doors unliock by pulling the handle. Only front doors will do that.
Old 03-30-12, 07:47 AM
jayclapp
jayclapp's Avatar
Absolutely, if I understand you. I have my car programmed so that all the doors unlock when putting the car in Park. Done by the dealer at my request.
larrydwyer
GX - 1st Gen (2003-2009)
03-25-21 01:26 PM
drewcam888
RX - 3rd Gen (2010-2015)
12-23-14 08:10 AM
bigblack06
10-14-11 09:56 AM
cleethree
05-25-08 06:15 PM
Lvangundy
08-10-06 06:28 AM
Quick Reply: Rear door lock question.
