How is this possible!!
Old 03-18-12, 12:48 AM
B43088
B43088's Avatar
Default How is this possible!!
So I'm out dc clubbing having a good nite, next thing I kno I walk to my car and the tire is dead flat. Luckily I had a full size spare that was my 1st time me actually using. But morale of the story is I didn't get any low tire pressure light before this happend and while the tire was dead flat? Curious to see if I have a dead sensor, taking it to Lexus of silver spring tommorow, hopefully they can give me an answer.
Old 03-18-12, 12:50 AM
B43088
B43088's Avatar
I was so embarrassed changing my tire in front of the club lol, it's like the nite I get me a good spot right out front that wants to happen 😨
Old 03-18-12, 01:20 AM
RA40
Super Moderator
RA40's Avatar
Likely picked up some road debris that caused it to leak out during the time you were away. This happens with fresh rubber on the car with my usual luck.
Old 03-18-12, 03:20 AM
caddyowner
caddyowner's Avatar
Someone may have flattened the tire simply because it was a nice car parked in front of a club.
Old 03-18-12, 07:50 AM
AlexusAnja
AlexusAnja's Avatar
It can easily happen.... you run over a nail/screw on the way and as you dance away the tire slowly leaks. Happened to my MDX, parked in garage and week later, flat from a screw and slow leak.
Old 03-18-12, 08:24 AM
AznRacer
AznRacer's Avatar
I had a blow out on the freeway before and i didnt get any light sensor either. I would like to hear what lexus say
Old 03-18-12, 11:29 AM
Gene01
Gene01's Avatar
The "tire pressure" indicator is derived from the wheel tick sensor, NOT a pressure sensor.
It is an indirect measure of pressure in that a tire with lower pressure will have a smaller diameter, and thus will rotate faster for a given ground speed. That generates more ticks than the calibrated value and the indicator is set ON.
Old 03-19-12, 03:10 PM
sojah
sojah's Avatar
Were u in SE? No lie, the best spots out in front of clubs in SE r usually somewhat managed by whatever lucky homeless/crackhead was able to claim that as their territory. If u don't tip them for using said spot this is common. A few years back I parked real close, tipped the man, asked him to keep an eye on it and to clean the rims. My boy got an even better spot on the other side of the club, I casually joked with him about us renting the spots, and he said I didn't tip the guy and infact told him to keep away from my car. I told my friend he better go check on his car. Wouldn't you know his window was smashed and his stock radio din was missing from his dash .
Morale of this story is to be nice to the homeless and tip them if its their parking spot. Who knows ur car might even be cleaner when you come back then it was when u left it
Old 03-19-12, 06:30 PM
B43088
B43088's Avatar
Gene01 your right that said sumthing like that about the sensor, but they also said mine wasn't working. Tire was unrepairable so ordering 4 new ones from tire rack.
Also sojah I was by club fur and ibiza, just if u ur thinking I'm 23 that's why I was at the young club😁… but no to familiar wit dc so I dunno wat part I was in. Deff will take that advice into consideration next Tyme I go out tho
Old 03-20-12, 10:38 AM
toantran99
toantran99's Avatar
Our car doesn't have tpms sensor. Check out Gene01 comment.
Old 03-20-12, 03:09 PM
AlexusAnja
AlexusAnja's Avatar
It doesn't have a direct tpms sensor in wheel, but there is a 'sensor' to monitor wheel rotation via the ABS.
kg19989
LX - 3rd Gen (2008-2021)
01-11-22 03:33 PM
stevelifts
04-10-18 06:35 PM
nicks88
02-25-14 09:47 AM
uae
03-10-08 09:16 AM
stefnee
05-13-06 01:59 PM
Quick Reply: How is this possible!!
