2001 LS430 Navigation issue - only one destination option?
On my drive over to my parents today, just for fun I
thought I'd set the nav as I have their place as a marked point. Well,
I noticed the address button was greyed out and so after lunch with
the folks I thought I'd try resetting the nav system with the fuse
reset method. Well now there's only the manual "map" destination
button not greyed out - everything else is totally greyed out and can't be pushed.
So I removed the battery connection for 10 minutes. Still not working (it tracks location live, you can select a destination manually by the map function and it routes, but the other destination methods aren't available). I ejected the DVD to have a look, and there is a minor scuff on it, and it could theoretically interfere with the read I guess, but then why would the map load at all?
I hope it doesn't mean I have to buy the new 7.1 DVD for $260- then again, I hope it is at worst that simple.
Thanks for reading. Any idea of how to fix this would be greatly appreciated..
Any ideas?
Jonny
I have a 2001 LS and I have had this same issue recently with the buttons grayed out when the car is in Park and not moving. Now I have a problem receiving a GPS signal and the GPS icon is not there under the arrow on the top left of the screen. Did you ever find out what was causing this issue? I upgraded my nav disk from the original 2001 disk in 2005 with the latest version at that time and had zero problems until a few months ago.
That would be a Manual reset. Often times with Computer components a disconnect for a few min will reset the system. Some INTERNET providers will tell you to unplug power for 10 min and then retry the unit.
OkNowWhat
04-21-17 09:30 AM
