1993-1994 ls400 y pipe
Old 12-02-16, 07:18 PM
YODAONE
YODAONE's Avatar
Default 1993-1994 ls400 y pipe
The entire Y-pipe, and catalytic converter mating flanges are toast.
Looking for aftermarket supplier of the following,
1.) Y-pipe with correct mating flanges that will work with OEM gaskets and;
2.) Catalytic converter "test pipes"; or alternatively
3.) Supplier of correct mating flanges for exhaust manifold (if not replacing catalytic converter ) and flange set between exhaust manifold for producing fabricated y pipe assembly
Old 12-02-16, 11:54 PM
dicer
dicer's Avatar
Find a good exhaust shop and take the old parts there for a pattern, my brother had good luck doing that with one of his cars. I would not take the whole car unless you don't care about all the banging around on the underside they would do trying to fit it.
Old 12-03-16, 11:18 PM
YODAONE
YODAONE's Avatar
Attached is an exhaust manifold flange for LS400 depicting machined ubdercut for nestling OEM gasket...
Anyone know who offers this part or if drawing. available .. I think I located on Lextreme...
Old 12-04-16, 03:00 PM
dicer
dicer's Avatar
The part has a spot face and a counter bore. If you get the dimensions I'd like to have them too.
Old 12-05-16, 07:14 AM
wnyjazz
wnyjazz's Avatar
I just had mine replaced on the '94.
https://www.clublexus.com/forums/ls-...or-a-94-a.html
Old 12-05-16, 06:00 PM
YODAONE
YODAONE's Avatar
Here is LEXTREME website where I located this part.
http://www.lextreme.com/allgo.html
Clicking on the image provides:
"Not Found
The requested URL /flange.html was not found on this server.
Additionally, a 404 Not Found error was encountered while..."
Does anyone have current contact info for Lextreme?
Someone has a drawing...
Old 12-05-16, 06:27 PM
YODAONE
YODAONE's Avatar
I located this link;
http://www.lextreme.com/forums/showthread.php?t=8315
Attached is drawing as "CAT.dwg" file.
The link also provides ".DXF" version.
Does anyone have software to open then convert to .PDF.?
Thanks.
Old 12-05-16, 06:39 PM
YODAONE
YODAONE's Avatar
This server states .dwg is an invalid file. Perhaps a member can tackle the software issue to download and convert file to .pdf.
Old 12-06-16, 07:52 AM
Losiracer2
Losiracer2's Avatar
Are the 95-00 models the same as earlier models? I have a Y-pipe I removed due my factory one hitting some road debris at some point in its life. Luckily i found a salvage guy that didn't use the jaws of life on his and was able to use that in my car.
Do you need one? I have a factory OEM Lexus one available, but it has a gash in one of the tubes, right before the merging to the 1 pipe. The cat is intact and still good and flanges are rust free since mine is an AZ car, it came right off with hand tools. PM me if you're interested.
Sherl
12
09-18-19 11:54 AM
SynicalVip
01-27-13 12:26 AM
Bradster
42
06-04-12 01:08 PM
TunerLexx
Performance & Maintenance
10-26-10 10:44 AM
Quick Reply: 1993-1994 ls400 y pipe
