Air conditioning Gen 1 LS400
Old 08-06-16, 09:58 AM
dicer
dicer's Avatar
Default Air conditioning Gen 1 LS400
conversion TSB: AC001-98
R12 to R134a AC Retrofit form Lexus .pdf
I found the above technical service bulletin in this thread.
https://www.clublexus.com/forums/ls-...s-400-a-c.html
The TSB says to use ND Oil 8, so spent some time yesterday online hunting for where to get it no luck. So I call my local Lexus dealer service department and ask, they say that they no longer do the conversion because the oil is no longer available, and he said that makes the conversion cost very high due to all the parts that need to be replaced.
In my search I found this site.
http://www.denso-am.eu/media/647317/...-a2_uk-web.pdf
It says ND Oil 8 is equivalent to PAG 46, but will it work the same as ND Oil 8 does in the conversion? I don't know.
Then I find this so I wonder if this is truly what it says it is?
https://www.moparrepairconnection.com/chemical/action/guide/en_US/AIR+CONDITIONING/82300102AC/
Oh and there was no mention of anyother TSB's on a conversion, I suppose they are thinking since the cars are so old and the cost of conversion is as high as or more than the car is worth they just don't bother.
Old 08-06-16, 12:30 PM
dicer
dicer's Avatar
Good news and some bad news too. 250 mL round can of ND-Oil 8 from Mopar dealer (that's the good news) $59.90 and of course 5.69 sales tax (that's all the bad news)
I suppose this is why most all r134a retrofits never last, no one is using the correct oil, that's mentioned in the TSB.
Old 08-06-16, 09:16 PM
AaronUCF11
AaronUCF11's Avatar
Im going to have to do this at some stage. There is enough r12 still in the system to run the compressor but not enough to actually cool.
Realisically the cost shouldnt be overly high, replace the oil, get adaptor fittings for the HP + LP lines, replace all the o-rings and the drier and you should be good to go, providing the system is otherwise in good order.
In Australia, flurocarbons are pretty heavily regulated. Ive seen you guys in the states to be able to DIY service systems and even buy R12! Ive got my A/c ticket but ive had very little to do with retrofitting/converting as most cars that are old enough that they use r12 are sub $1000 ****ters anyway so people dont spend the money.
Old 08-06-16, 10:12 PM
dicer
dicer's Avatar
I'll add comments when I can.
Attached Thumbnails Air conditioning Gen 1 LS400-2nd-hp-port.jpg   Air conditioning Gen 1 LS400-2nd-sight-glass.jpg   Air conditioning Gen 1 LS400-low.jpg   Air conditioning Gen 1 LS400-reciever-dryer.jpg   Air conditioning Gen 1 LS400-hi-air.jpg
Old 08-07-16, 02:32 AM
dicer
dicer's Avatar
Top left picture shows high pressure port, there are 2 of them the other is under the airfilter the fan is the one on the right side of car.
Top center picture shows 1 of 2 sight glasses, the other is on the receiver drier.
Top right picture shows low pressure port near fire wall on the right side under wire loom that goes into the passenger compartment.
Bottom left shows right side head light assembly taken out and the receiver drier and the sight glass.
Center bottom shows the high pressure fitting under the airfilter, its the pipe to the bottom.
Old 08-07-16, 04:05 AM
AaronUCF11
AaronUCF11's Avatar
I cant recall seeing multiple sight glasses or multiple high pressure ports on a car before. I also noted i have lines running to the rear of the car into the trunk where the rear a/c used to be (i have a CF celsior, dont think LS had this option?). I havent really payed any attention as to where they are in the system up in the engine bay. I maybe able to delete them completely.
Old 08-07-16, 04:12 AM
AaronUCF11
AaronUCF11's Avatar
Also did you look on ebay for the ND 8 oil? I just did and got several hits.
Old 08-07-16, 09:17 AM
python
python's Avatar
anytime i switch from r12 to r 134 ester oil is to be used
r 134 retrofit never lasts? mine was done 6 years ago
Old 08-07-16, 10:11 AM
oldskewel
oldskewel's Avatar
Same thing with R12.
Old 08-07-16, 11:29 AM
dicer
dicer's Avatar
I did about 2 days ago and got nothing. Things change on ebay.
The system on this car was empty, still up in the air what I'm going to do to find the leak. Even if it could be recharged with R12 a person would want all new orings and all new anything else that could possibly leak, its just too expensive to not make sure there are zero leaks. And never would you want to use dye and R12 total waste.
Old 08-07-16, 11:30 AM
dicer
dicer's Avatar
The Lexus Technical Service bulletin specifically says to use ND Oil 8, please explain why we should use something they didn't specify?
Old 08-07-16, 12:07 PM
python
python's Avatar
ester oil is what is used when retrofitting from 12 to 134. ester is made to mix with any residuals...pag is not. newer synthetic oils have been introduced,they are safe to use. as a rule ester has been the norm.
Old 08-07-16, 12:29 PM
CELSI0R
CELSI0R's Avatar
Thank you for the very detailed information, Dicer!
EDIT: Nevermind my initial question in this post. I can see the bolt in one of your photos.
dicer
dicer's Avatar
I do remember reading that some place and agree with you, I would still like to know why Lexus came out with the TSB saying what they did? I know they would have to warranty the work and thus the system if they did that retrofit so they must know something we don't. And yeah the ND Oil 8 is a PAG oil ??????
https://macsworldwide.wordpress.com/...bricant-types/
Old 08-07-16, 07:25 PM
python
python's Avatar
46 to be exact..
Quick Reply: Air conditioning Gen 1 LS400
