UCF20 Rear Upper Control Arms install question
Old 05-14-16, 12:16 PM
Kaiyin
Kaiyin's Avatar
Default UCF20 Rear Upper Control Arms install question
Has anyone done the rear upper control arms on a ucf20 before? How did you get the nut that holds the ball joint off? I've got mine mostly torn apart and can't get that nut off. Seems like the axle needs to come out?
No, I'm not replacing my RUCA because they went bad. I finally got SerialNine RUCA
Any tips would be appreciated. I'd like to get this done myself before I have to bring it to a friend's shop. I'm out of ideas!
Old 05-14-16, 04:05 PM
valex
valex's Avatar
You have to remove the Rear upper control arm attached to knuckle and then disconnect the ball joint from knuckle when it's off the car. The nut is not reusable per service manual.
Old 05-14-16, 09:28 PM
valex
valex's Avatar
on 1998-2000 it is this parts number, not sure about earlier years.
Attached Thumbnails UCF20 Rear Upper Control Arms install question-nut123.jpg
Old 05-15-16, 08:09 AM
valex
valex's Avatar
I forgot to mention that new rear UCA come with those new nuts!
Old 05-15-16, 09:32 PM
Shmee
Shmee's Avatar
Pretty sure you either need a special tool or you have to pull the driveshaft out of the knuckle, which means you have to disconnect the lower arms from the knuckle to get the driveshaft out. Once it's out, you can easy get at the nut on the RUBJ and then knock it out with a long punch/drift once the nut is off.
Returd
Suspension and Brakes
07-02-22 06:37 PM
SC3coupe
09-09-13 03:00 PM
GS4hunnit
06-29-13 11:00 AM
Lexus082
05-05-09 06:50 PM
T0ked
01-13-04 10:39 PM
Quick Reply: UCF20 Rear Upper Control Arms install question
