Please Help battery keeps dying
Hi I don't have a lot of experience with cars I have a 2000 LS400 the battery keeps dying about once a year my mechanic checked for any shorts but didn't find any is there a known issue?
it also has terrible gas mileage (about 10 mpg city) any way to improve it?
Thanks,
Sam
Thanks,
Sam
Try connecting a scan tool to the obd port after engine is warmed up. What does the temp read? Maybe engine temp sensor is bad and so engine is running rich 100% of the time?
Alternator on its way out?
I had that problem with mine... the alternator was over charging the battery due to a bad regulator. I'd have the tech check out the alternator output and make sure it's within spec.
I'm going to check tomorrow its supposed to be a little warmer
You can get a cheap Bluetooth off eBay and use it with the torque app.
The ect sensor reports a temp to the computer, the scanner just reads it. Your temp gauge may be just below half, normal but the ect sensor may think the engine is not warmed up and so adds extra fuel.
The temp sensor and temp sender for the gauge are different.
either way I'd like to have one on hand does look ok
Ok so I checked the alternator and its giving me a consistent 14.4v
No parasitic draws
I also checked the battery and its only at 12.05v and I only got it a few months ago
any other ideas?
No parasitic draws
any other ideas?
Ok so I got the scanner today and it looks like the ECT temp rises the guage on the dash was about 25% and the temp was reading 68 celcius
is that normal?
what next?
is that normal?
what next?
