1998- 2000 LS400 Transmission Line Cushions
The transmission oil to radiator heat exchanger lines utilize elastomeric isolation cushions at clamp areas depicted in attached photographs and Lexus exploded parts diagram.
Require quantity four of Lexus P.N. 32926-30020
Less than $2.00 each (one-thousand State-side inventory)
Those in the 1999 LS400 were rock hard and so brittle as to disintegrate.
Simply unbolt clamps and the old cushions will easily slip off or crumble away.
Slip on new cushions and apply clamps, being mindful of indexing of cushion slit in relation to the clamp bracket.
Old oil cooler line cushions
Parts 3296 are oil cooler line cushions.
Rear set of cushions just below passenger side exhaust manifold at connector for upstream oxygen sensor
Front set of oil line cushions on passenger side above oil pan front right corner
New cushion
New cushion
AlaskanLS
08-29-18 11:08 PM
Elless400
15
10-27-17 12:16 PM
