What is't ?
Old 08-23-15, 08:44 AM
Medved
Medved's Avatar
Default What is't ?
hello all, can you help me. I have an LS400 92. What is it? where should I put it? Thank you. And excuse me for my poor english
Old 08-23-15, 09:10 AM
deanshark
deanshark's Avatar
What is it?.......Its a ground wire. That bracket, I'm pretty sure, bolts to the A/C. I know I've taken it off whenever I did my timing belt. If you cant find where it goes you should at least bolt it to the engine (anywhere) so that its grounded properly.
What type of work have you done recently? Is this something you forgot to put back on or did you just find it hanging there?
Old 08-23-15, 09:23 AM
Medved
Medved's Avatar
thank you for that answer, I bought my LS400 disassembled. without knowing what the previous owner had done it.
Old 08-23-15, 05:44 PM
dicer
dicer's Avatar
By AC he means the Air-conditioning pump. It goes under the ac pump and in front of the oil filter, lucky I looked I'm missing the bolt that holds it to the AC pump bracket. And that is a very important wire, a main ground to the engine.
Old 08-23-15, 10:12 PM
Medved
Medved's Avatar
thank you dicer for your answer,i try it
TRD911
02-20-15 07:39 PM
FICMrepair
06-28-13 02:17 PM
SC4NLV
SC- 1st Gen (1992-2000)
06-27-10 08:18 PM
kolofai
10-14-02 05:32 PM
Quick Reply: What is't ?
