Help Lexus engine oil
Old 05-21-14, 08:04 AM
king98
king98's Avatar
Default Help Lexus engine oil
hello I owned a Lexus LS400 1998 how much liter Engine oil with filter :
Old 05-21-14, 10:44 AM
timmy0tool
timmy0tool's Avatar
i always buy 6 quarts, put 5.5 in and run the car for a few minutes. shut it off and wait for the oil to drip back down and top off as necessary. it all depends on the filter as some are bigger than others.
this is for a 1st gen but very similar.
http://www.lexls.com/tutorials/lubri...oilchange.html
Old 05-21-14, 10:45 AM
Legender
Legender's Avatar
If I remember correctly it should be 5.5 quarts... it should be in your owner's manual also.
Old 05-21-14, 12:27 PM
sha4000
sha4000's Avatar
I just drained my oil and changed the filter. I let the car sit and jacked up the drivers side some to make sure alk the oil was out too. It took almost 8 quarts to get it up to the to line on the dipstick.
Old 05-21-14, 01:43 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
that's way too much O.o. more than even the dry fill capacity of the sump.
Old 05-21-14, 01:59 PM
sha4000
sha4000's Avatar
I know so I'm going to keep a close eye on it.
Old 05-21-14, 02:48 PM
Aeok18109
Aeok18109's Avatar
holy crap thats over full LOL. wow. 5.5qts sir thats all ya need. big jug and a single from walmart is like $33. mobil 1 full syn 5w30
Old 05-21-14, 03:28 PM
timmy0tool
timmy0tool's Avatar
you sure you're on level ground? 8 is way too much, from low to high on the dipstick is only 1 quart!
Old 05-21-14, 04:57 PM
sha4000
sha4000's Avatar
Your right the car is still parked in the same spot and there is a slight decline to the curb. I'll check it in level surface. Guys I'll have to drain some of that out of there.
Old 05-21-14, 05:00 PM
python
python's Avatar
Dommm
05-08-17 05:32 AM
Fritz330
13
07-16-14 11:00 PM
dmight
08-31-11 12:29 PM
love67
07-04-09 01:37 AM
is350matic
12-10-06 05:03 PM
Quick Reply: Help Lexus engine oil
