Leaking onto my exhaust...
Old 04-24-14, 06:21 PM
cgawelko
cgawelko's Avatar
Default Leaking onto my exhaust...
What the heck is this? Its leaking onto my exhaust pipes and if its gas, im going to be mad.
Attached Thumbnails Leaking onto my exhaust...-img_20140424_181610.jpg   Leaking onto my exhaust...-img_20140424_181532.jpg
Old 04-24-14, 06:56 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
gas area looks wet, cv boot looks dry...
Old 04-24-14, 06:59 PM
cgawelko
cgawelko's Avatar
So is that gas? because its on both sides they look like that...
ANY possible chance its oil from the air compressor and lines to the rear suspension that was swapped to coils??
Old 04-24-14, 07:18 PM
cgawelko
cgawelko's Avatar
Alright fine. what do you suggest replacing???
Old 04-24-14, 08:07 PM
Gene01
Gene01's Avatar
If it's gas, you're not going to me mad, you're going to be dead!
Old 04-24-14, 10:41 PM
RA40
Super Moderator
RA40's Avatar
Looks oily like brake fluid residue. Get your fingers up around those hard lines and verify what it is. Other symptoms would be dropping brake fluid in the reservoir. Are you noticing a drop in any fluids?
Old 04-24-14, 11:18 PM
Jordanf
Jordanf's Avatar
Best thing to do would be clean and degrease the entire area, drive, then get under the car and see what's leaking at the highest point. Otherwise you'll be just throwing money at random parts
Old 04-24-14, 11:41 PM
cgawelko
cgawelko's Avatar
These are responses I was looking for!
RA40, what makes you say brake fluid? It would make sense considering the pedal has some sponge to it, but nothing I wouldnt expect from an older car. The reservoir is fine on level, but I should probably check again. It is oily and it doesnt smell like gas, but gas stops smelling bad after it evaporates.
I was thinking of pulling my gas tank tomorrow and getting a good look in there. I hope its not the hard lines for the brakes... and if I take the tank out, then I have to buy a bunch of gaskets because most of them are not reusable.
Old 04-25-14, 12:43 AM
RA40
Super Moderator
RA40's Avatar
Don't drop the tank, that is unnecessary at this stage.
Differential fluid has a very distinct smell as well. When was the last time you had the fluid back there drained? If one of the seals has gone south in the carrier this may also be an origin for fluids. As it migrates out, the rotation of the axles may cause it to disperse on the underside like that. If it is oily, the source of such fluids is limited back there. Brake fluid or diff fluid. Unless you have some mess in the spare tire well that is leaking out but that is further back and I don't recall if there is a drain plug.
Old 04-25-14, 04:09 AM
cgawelko
cgawelko's Avatar
Its oily and its attracting dirt. doesnt seem to burn off well because I drive 30 miles each way to work and I have not been burned to a crisp yet
Old 04-25-14, 04:20 AM
Yamae
Yamae's Avatar
I doubt the grease coming out from the boot judging from the length of the darker part.
Old 04-25-14, 04:23 AM
cgawelko
cgawelko's Avatar
the cv boot was eliminated previously due to the metal above being consistently wet. Im starting to think its brake fluid personally based on the metal being wet
Old 04-25-14, 06:47 AM
akitomk3
akitomk3's Avatar
I would think it's some sort of grease/oil fluid like brake fluid or rear end fluid. Gas wouldn't attract dirt at all. I would keep an eye on your brake fluid, a tiny hole could seep and keep enough pressure in the brake systems for a while. What i don't get is this happens on both sides?
Old 04-25-14, 06:59 AM
cgawelko
cgawelko's Avatar
Boom. Thats my confusion too. The drivers side is like 1/4th as bad, but same deal. wet metal feel attracting dirt. Thats why my first thought was air suspension leaking because the back was switched to coils but all the stuff is still there.
808_GS400
Suspension and Brakes
10-09-22 08:17 AM
daddiojigg
07-20-18 09:41 PM
ToyotaLexus
02-16-09 07:46 PM
autoboy
08-14-07 11:09 PM
Quick Reply: Leaking onto my exhaust...
