Bleeding brakes help
Old 03-11-14, 12:33 PM
Ef8people
Ef8people's Avatar
Default Bleeding brakes help
Am I supposed to turn the car on when I bleed my brakes?
Old 03-11-14, 01:03 PM
Shmee
Shmee's Avatar
Ignition on with the engine off is required of suggested for most cars with ABS brakes.
Old 03-11-14, 04:52 PM
Ef8people
Ef8people's Avatar
Thanks. But found out my calipers are out
Old 03-11-14, 05:55 PM
Largefarva
Largefarva's Avatar
Car off, key off for most cars, not sure about Lexus but some older GMs with 1st gen abs need a special procedure.
What does "my calipers are out" mean?
Old 03-12-14, 08:23 AM
python
python's Avatar
car off..key off. if u run the system dry with the key on ur screwed.
Old 03-12-14, 11:01 AM
MattLS400
MattLS400's Avatar
Is it even safe to bleed these cars ?? I mean, given our 15 - 20 year old boosters
Old 03-12-14, 11:05 AM
Shmee
Shmee's Avatar
Why would the booster be a concern?
Old 03-12-14, 11:20 AM
timmy0tool
Forum Moderator
timmy0tool's Avatar
booster only works when the car is on. it's the master cylinder that does all fluid transfer as well as the ABS module.
calipers out meaning they are stuck or seized i assume?
Old 03-12-14, 11:58 AM
MattLS400
MattLS400's Avatar
sry guys, I meant Master Cylinder
Old 03-12-14, 12:29 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
lol if it wasn't safe to bleed what makes you think it would actually work at all?
Old 03-12-14, 12:37 PM
Shmee
Shmee's Avatar
If the fluid in the master reservoir is black and is loaded with gunk, sure you may have issues bleeding your brakes, because of such poor maintenance habits of you and/or PO(s).
Pumping that crap through a master is a good chance of damaging seals.
Additionally, such crap in the reservoir is also an indicator that there is a good chance of corrosion/pitting on the master cylinder sleeve. this is an issue when bleeding as full stroking the master will often drag the seals over the rough sections outside the normal stroke and rip up the seals, resulting in a bypassing master.
DrBrown54
Suspension and Brakes
09-14-15 06:23 AM
MattLS400
10-17-13 07:06 PM
Lukas99GS
09-16-13 10:14 PM
D-Boi
07-23-10 10:35 PM
Quick Reply: Bleeding brakes help
