LS400 to manual help ?
Old 10-26-12, 09:55 AM
TheGerman
TheGerman's Avatar
Default LS400 to manual help ?
What flywheel should i use?
I here beams flywheels fit if you slot the crank holes? what is the pcd of the bolt holes on a 1uzfe crank? Will an altezza flywheel do the job?
Does anyone know will an altezza clutch suit a w series gearbox? (same splies)
Thanks
Old 10-26-12, 10:06 AM
TheGerman
TheGerman's Avatar
Also what LSD fits them, car is 1990
Old 10-26-12, 02:30 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
www.lextreme.com for more info, there's no bolt-on flywheel setup for a 1uz. the flywheel you use depends to some degree on which transmission you're using. The clutch will depend on the flywheel obviously, and trans.
www.1uzfeswapkit.com is a popular source for manual trans conversion parts.
mkiv supra LSD is the only one that MAY work, and only the internals will change in, not the complete pumpkin.
please use the search function before posting any more new threads.
Old 10-26-12, 05:14 PM
mikes7ke
mikes7ke's Avatar
If you're serious about the swap I suggest you install clutch pedal and clutch master cylinder.It was the worst part, in my opinion. And make sure you consider which slave cylinder/throw out bearing you will use before deciding master cylinder. I didn't think it through- chose a SC300 clutch master cylinder and T56 hydraulic throw out bearing. The SC300 clutch master cylinder has a 5/8" bore. I have the push rod adjusted to the limit and it just barely disengaged the clutch when I press down the clutch pedal. I will be installing a 3/4" bore clutch master cylinder tomorrow.
If you go with a W58 or R154, the second link PureDrifter provided will make your life easy. I used that adapter plate to mate the 1UZ automatic transmission bellowing to a W58. And used a 3S-GTE clutch and pressure plate.
The shift linkage will need to be lengthened about 7". Driveshaft Shop recommends a 3.5" diameter aluminum driveshaft if you want a one piece shaft. If you do go with a 3.5" shaft, the linkage will also need to be raised about an inch. And you'll need to "massage" the transmission tunnel for clearance.
With some modification someone swapped in a mk4 supra pumpkin. I think some welding was required at the least and he swapped in the entire rear crossmember.
There is (was?) a Japanese web site listing lsds for the ls400 but they were something like $2500 or $3500.
Old 11-01-12, 10:30 AM
TheGerman
TheGerman's Avatar
Thanks guys, iv had a look there but havent found any of that info,
does anyonce else know or have anyother links?
Thanks
Old 11-01-12, 12:28 PM
PureDrifter
BahHumBug
Thanks
https://www.clublexus.com/forums/search.php
will probably help you the most. you can also limit your searches to the LS forum.
captainsc
Performance & Maintenance
11-26-11 12:51 PM
bzebern
SC400 / 300 Classifieds
03-16-11 07:16 AM
yihaw
12-12-08 07:54 AM
shonuff53
11-16-07 11:00 PM
Shellhouse
SC- 1st Gen (1992-2000)
12-13-01 09:12 AM
Quick Reply: LS400 to manual help ?
