timing issues on 93 LS 400
So here is the skinny, I am doing my fan bracket. Getting ready to put every thing back together. I marked the crank shaft with the mark on the engine. what else do I have to do. I know when I tried to remove the crank pulley nut, I turned the engine over a couple times. should I be worried. Was I suspose to mark the timing belt to make sure that goes back in the same spot. Iam a lil worried. Anybody have any knowledge in the area???
You made sure to align the timing belt marks with the mark on each cam pulley also, right?
As long as you make sure everything is lined up when putting it back together, everything should be fine when you start it up. If not, as stated above it's a non interference engine. Just do it all again and make sure it's lined up.
AlaskanLS
11-09-17 10:36 AM
madmax98
16
01-17-08 09:03 AM
