Rough idle and stalling
Old 05-15-12, 04:12 PM
LS400Sal
LS400Sal's Avatar
Default Rough idle and stalling
Ok so i got a 1994 lexus ls400 and its been sitting for a while. i did a oil change and changed the spark plugs the other day also i cleaned the iacv. It started but when it idles it sometimes shuts off it also shuts off when i try to touch the gas pedal.. could this be a fuel pump problem??
Old 05-15-12, 05:36 PM
matchesLS
matchesLS's Avatar
Did it run good prior to your maintenance? I'll be honest, I'm not sure with these cars but in my experience with other cars, when the fuel pump goes, the car just won't start. The pump just dies. I would check you work and make sure all is correct.
Old 05-16-12, 02:03 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
no it sounds like you put the wires on in teh wrong order or not firmly seated...
Old 05-18-12, 12:21 PM
LS400Sal
LS400Sal's Avatar
yea it ran fine.. someone told me today it could be the fuel pressure regulator..
LS400Sal
LS400Sal's Avatar
the spark plug wires you talking about??
Old 05-18-12, 12:23 PM
LS400Sal
LS400Sal's Avatar
nah its not the wires i just checked them
Old 05-21-12, 07:16 PM
Leolo007
Leolo007's Avatar
I suggest that you check the gap on the spark plugs
Old 05-22-12, 12:17 AM
cobalt91
cobalt91's Avatar
Recheck you iac valve and gasket.
Old 05-22-12, 09:36 AM
Dtwillis5
Dtwillis5's Avatar
Check for un burn fuel (glowing catalytic converters) also it can be a ecu problem. I had a problem like yours when my car reach 1700rpms it would cut off I change the ecu now it rev all the way up. This just something to look at.
Old 05-22-12, 11:47 AM
crcuevas
crcuevas's Avatar
I have the same problem. My LS400 94 runs great when idle until I rev it beyond 1400 rpm and it wants to die. How do you know if the ECU is bad?
Old 05-22-12, 05:06 PM
Dtwillis5
Dtwillis5's Avatar
I had a cel and wasn't getting any codes so,that let me know I needed a ecu. I change the ecu and just so happen it fix that rev problem. Now it don't cut off when I give it gas but, it still have the lack of power like 4 cylinders . I replace my coils that fix everyone else problem. I guess next is to check the cam-sensor?
Jesse1984
Performance & Maintenance
02-19-13 07:20 AM
1985zcar
15
11-25-08 10:17 PM
WVGS4
11-04-07 03:46 AM
rpk2012
GS - 1st Gen (1993-1997)
12
10-13-06 12:28 AM
Quick Reply: Rough idle and stalling
