New Guy... Question about shock tower
Old 04-07-16, 09:39 AM
Tonyucf20
Tonyucf20's Avatar
Default New Guy... Question about shock tower
Hey guys. My name is tony.. if anyone is from the honda scene back in the day my user name was tony_em1. Anyways I'm new to the ls400 platform but am enjoying the car a lot. Bought it about a year ago and recently started messing around with her. I just finished bagging it this weekend and can't lower the front any further do to the upper control arms hitting the shock tower from underneath. Was wondering if any of you could point me to a thread dealing with this very issue. Thanks in advance
Old 04-07-16, 10:14 AM
RA40
Super Moderator
Senior Moderator
RA40's Avatar
Welcome and a congrats on the nice looking LS.
For those wanting that low a setting, clearance holes are cut into the towers.
Vincent's thread has what he did for that height situation:
https://www.clublexus.com/forums/bui...f21-build.html
Old 04-07-16, 10:44 AM
Tonyucf20
Tonyucf20's Avatar
Thank you very much. found what i needed in that thread
Old 04-07-16, 11:51 AM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
clearance holes just be sure to drill a pilot hole from under the car upwards (with the hood open and wires moved out of the way) so that you center the holes in the right spot. You'll miss if you try to drill initially from the top down.
Don't make a bigger hole than what you need, you can always make a smaller hole bigger.
Old 04-07-16, 12:03 PM
Tonyucf20
Tonyucf20's Avatar
Thanks for the advise
Old 04-07-16, 12:58 PM
timmy0tool
Forum Moderator
timmy0tool's Avatar
yes def drill upwards first. you should see a mark where the upper a-arm was striking onto the inner well. use a special hole saw that can cut metal! also there is no need to box it up as in vincent's thread. dirt and debris barely does not enter in there anyway, plus there usually isn't any structural concerns either.
curious to your air setup man!
Old 04-07-16, 01:32 PM
Tonyucf20
Tonyucf20's Avatar
Thanks for the advise man. ill post a picture soon. my trunk isn't ready but ill post an ugly pic soon
Old 04-09-16, 09:25 AM
sndlight
sndlight's Avatar
I know this is a lil late , but here's mine before I painted it up. 2.5" hole saw, took 5 minutes per side.
Old 04-15-16, 08:37 AM
Tonyucf20
Tonyucf20's Avatar
Thanks. I almost did this yesterday but ended up not going through with it because the stock exhaust on these cars hangs to low and I am already touching the ground when i air it out now. Anyone have pictures of tucking their exhaust to lower the car on the way to the floor? any one else run into this problem besides me?
Old 04-15-16, 12:40 PM
RA40
Super Moderator
Senior Moderator
RA40's Avatar
Yes, several contained within the build threads about tucking exhaust to gain 1-1.X" of additional clearance. Vincent's thread later on I recall him outlining what he did for his exhaust.
Old 04-17-16, 04:17 PM
Hiroshi12
Hiroshi12's Avatar
If you haven't considered this already - the moog uca's (still carried at Rock Auto?) have a 1/2" shorter ball joint than stock which can help a bit.
Old 04-18-16, 03:07 AM
Pistachio
Pistachio's Avatar
You won't get much lower with the exhaust tucked. Maybe like half an inch lower but your upper control arm will reach max travel through the hole already. If you want to go lower in the front, you'll need shortened spindles. I would recommend drilling out the holes anyways to avoid that knock when you bottom out. Let me know what area you are in. I think I've seen you around. I have extra grommets to give you if you do 2 3/4 holes. This prevents water from splashing up into the engine bay.
Old 04-27-16, 12:05 PM
Tonyucf20
Tonyucf20's Avatar
New Guy... Question about shock tower-img_20160224_175153_85a8041f4087e0de12357d20a303638c61bf86a9.jpg
Thanks for the info. Im in the 626 area let me know if you are close by and i'll pick them up. thank you
Old 04-28-16, 02:18 PM
ALtin107
ALtin107's Avatar
Very nice looking LS. Is that limo tint all around?
Old 04-28-16, 02:32 PM
Tonyucf20
Tonyucf20's Avatar
ya and the windshield is tinted too.. I'm about to remove it tho. tired of getting pulled over lol
Youngrobot
07-22-17 06:05 PM
jdog0411
04-13-11 11:29 PM
Tibbetsni
02-10-08 01:23 AM
Quick Reply: New Guy... Question about shock tower
