Vibration when braking, bushings?
Safety issue
Any problems with the front end can become VERY dangerous in the wrong situation. Once restored a '77 Datsun 280Z, I didn't realize it at the time but the rack & pinion steering bushings (about the size of a donut) were disintegrating, never felt anything amiss in normal driving but one day while running thru a twisty road in the mountains I went into a low sweeping turn and hit a bump mid turn that set up the WORST oscillation in the front end I'd ever experienced, like a rowboat in a storm, the front end violently wobbled from side to side. At higher speeds I could have easily gone off the road. Once it stopped it felt 'normal' again. I'll take warped rotors over that any day.
BahHumBug
1LS strut rod bushings are relatively expensive because they are quite complicated, with a metal clamshell, pivot-style bearing, and the bushing material. 2LS strut rods are literally a single bushing on each side that gets pressed into the rod. OEMs are ~$60ish each side (bushing only) or ~$100/side for the complete bar/bushing. poly strut rod bushings are ~$35-40/side.
learn to read. jason has a 2nd gen.
lexusdon
05-10-09 08:15 PM
