Low Idle In Drive = Vibration?
Old 08-22-14, 10:21 AM
  #31
RugbyDad
RugbyDad's Avatar
Originally Posted by sha4000
The PCV is on the drivers side of the engine in the area of front of the valve cover.
to expand on what sha said: IIRC find the oil dipstick. that rubber L shape grommet/hose to the very left front of it holds the pcv valve. I may be wrong although i'm 95% sure, haven't looked in awhile.
Old 08-22-14, 12:52 PM
  #32
sha4000
sha4000's Avatar
here you go, you see that hose right under the wire harness?
Old 08-23-14, 11:19 PM
  #33
Kram
Kram's Avatar
I had this problem on my friends 1993 and it turned out to be the mas air flow sensor He installed an after market hi pro one and it cost under 125.00 .I can only quess that all this cleaning can damage mas air flo sensors from what the book says.good luck.One more thing,We need to be nicer with are comments and suggestions to all the club members I just read about a member with a blown head gasket problem and the help was right but no need to get crazy and name calling,Not everything will help or be right but at least we are all trying to help.I have had to back off with my help because of so mean comments to my suggestions.
Old 08-24-14, 09:44 AM
  #34
Odzsee
Odzsee's Avatar
THX Guys,
I find Toyoidy parts catalog.
Old 08-24-14, 09:55 AM
  #35
Odzsee
Odzsee's Avatar
The 12204 part of the PCV valve?
Old 08-24-14, 10:41 AM
  #36
RugbyDad
RugbyDad's Avatar
Yes, that is the PCV.
Old 08-24-14, 04:31 PM
  #37
Garage7RP
Garage7RP's Avatar
Check the specs on both TPS. If it is working properly, check if it is properly adjusted. Also check the TPS harness to ecu. This should fix the low idle problem.
drseth
Performance & Maintenance
05-21-17 05:39 PM
OBEY414
01-15-12 09:52 AM
97-SC300
01-27-11 09:18 AM
DK Audio
21
03-02-10 12:06 PM
Flex33
03-04-08 08:41 PM
Quick Reply: Low Idle In Drive = Vibration?
