tail light failure
tail light failure
Hi my ls400 is reading tail light failure. I look in the back and don't see any light off. Also is there any picture on how to chance the light bulb in rear of car.
The tail light bulbs in the trunk lid are behind trim flaps you will see when you open the trunk lid -- should be obvious how to change them or at least I found it to be.
The bulbs in the fender mounted tail lights of a 98 LS are changed after removing the lamp assembly from the fender. When the trunk lid is open, you will see the screws holding the lamp assemblies to the car.
I posted a picture of what the high mounted stoplight looks like when removed in this thread: https://www.clublexus.com/forums/ls4...placement.html
To remove the high mounted stop light, you lift up the front of the stop light assembly until the plastic red tabs clear the hat shelf. Be careful to not break the tabs.
