Road noise from front end
Old 01-11-11, 12:31 PM
willcrets
willcrets's Avatar
Default Road noise from front end
My '96 LS400 has a lot of noise from the front end on street bumps and on expansion joints of concrete roadway. When the car hits a dip and then back up, there is a "slap" on the floorboards. From reading the posts I felt the problem must be the front ball joints. My neighborhood mechanic refused to replace them saying that his examination revealed no problem with the ball joints. So I still have a lot of noise in the cockpit. Can the health of the ball joints be determined by only examining the ball? Advice welcome!
Old 01-11-11, 12:55 PM
StevieA
StevieA's Avatar
It took my Uncle and I quite a while to determine for sure the knocking noise through the floorboards was the ball joint. We went for multiple rides with his "mechanical stethescope" attached to many different front end parts until we clipped right to the ball joint then we heard it. The only way we could determine play in the ball joint while mounted was removing the wheel and using a crow bar to pry the ball joint up & down from of it's socket. Then it was OBVIOUS. But other tests for play (side to side etc.) did not reveal it was worn. I can't explain them all because it's from memory but my Uncle has been a mechanic since the mid 1960's and his specialty was front end alignments.
We replaced the upper control arms with a set off Ebay and the ride improvement was significant and the knock was gone.
However note that my noise would happen when running over small "pebbly" gravel like on a dirt road - not large bumps like speed bumps so your problem may be different.
Old 01-11-11, 01:06 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
more likely to be strut rod bushings or control arm bushings if there's not any visible play in either upper or lower ball joints. also make sure the subframe bolts are tight.
Old 01-20-11, 08:23 AM
willcrets
willcrets's Avatar
I had the lower ball joints replaced ($184 parts, $195 labor). After removal, it was determined there was a lot of play but my slapping problem on dips is not remedied. Maybe front struts are bad???
Old 01-20-11, 12:06 PM
JimsGX
JimsGX's Avatar
Do you hear it on both sides, one side, middle?
Old 01-22-11, 05:01 PM
bdshomes
bdshomes's Avatar
I have a 95 LS that just developed a rattling/knocking sound coming from the right front end while driving down the road. The slighted of unevenness or small bumps in the road will cause the sound to happen. It sounds like something is loose like a break calipure so I took it to an alignment/front end shop this afternoon and they seem to think it could be either a busted strut rod mount or one of the front end bushings. They put it on the rack and spent about 20 minutes inspecting different parts and moving them around with a long pry bar.
Has anyone ever had a strut mount break?
Old 01-22-11, 08:49 PM
billydpowe
billydpowe's Avatar
if it was mine, I would replace the strut rod bushings......
Old 01-24-11, 10:07 AM
bdshomes
bdshomes's Avatar
thanks for your input Billy, i will definitely look into that. It almost sounds like a front spring is broken and the two parts are now rattling against each other..i read on another Lexus forum that scenario can be one of the possible issues to trouble shoot with the noise issue going on.
I also read in that thread that one guy replaced every single bushing on his front end trying to solve his problem and finally discovered the noise was coming from a broken strut mount. My mounts from the outside appear to be fine,but not sure whats going on underneath the mount.
Old 01-24-11, 10:26 AM
willcrets
willcrets's Avatar
Yes, I hear it from both sides...maybe worse on left side. Noise from ribs across a concrete road seems to feed directly into the cabin. I wonder if the Lexus dealer could diagnose the problem? Replacement of the lower ball joints did not help.
Old 01-24-11, 01:11 PM
etex
etex's Avatar
As has been said, replace the strut rods.
DosyBoy
10-02-12 08:46 PM
JDMCelsior
06-03-09 10:39 PM
minla007
Suspension and Brakes
08-15-06 01:26 PM
ajv258
07-28-03 09:12 AM
Quick Reply: Road noise from front end
